08-26-2004 03:16 AM - edited 03-09-2019 08:36 AM
Hi all,
is it perhaps possible to upgrade the PIX-515E-R
with this PIX-515-MEM-32 upgrade, without paying
for the whole PIX-525-SW-R-UR= license upgrade.
Richard
Solved! Go to Solution.
08-26-2004 07:10 AM
The PIX will recognize this new memory but the configuration is not supported. The UR upgrade is memory as well as a license upgrade for more interfaces, failover, etc... Unless you are going to be adding these features to your PIX, there is no need for the memory upgrade. 32 MB is more than enough for a PIX 515R.
Does this help?
Scott
08-26-2004 05:21 AM
Hi!
The Below Document will give you clear idea.
HTH.
Rgds
Vimal
08-26-2004 05:47 AM
Thanks for you Info,
maybe i did not place my question clearly:
If I get this PIX-515-MEM-32 and install it in a
PIX-515E-R --- will it be recognised.
Richard
08-26-2004 05:47 AM
Thanks for your Info,
Richard
08-26-2004 07:10 AM
Does this help?
Scott
