PIX-515E-R-BUN MEM upgrade with PIX-515-MEM-32
richard.werner
Hi all,
is it perhaps possible to upgrade the PIX-515E-R
with this PIX-515-MEM-32 upgrade, without paying
for the whole PIX-525-SW-R-UR= license upgrade.
Richard
The PIX will recognize this new memory but the configuration is not supported. The UR upgrade is memory as well as a license upgrade for more interfaces, failover, etc... Unless you are going to be adding these features to your PIX, there is no need for the memory upgrade. 32 MB is more than enough for a PIX 515R.
Does this help?
Scott
Thanks for you Info,
maybe i did not place my question clearly:
If I get this PIX-515-MEM-32 and install it in a
PIX-515E-R --- will it be recognised.
Richard
Thanks for your Info,
Richard
Does this help?
Scott
