"Catalyst 6000 IDS Module" NICs
igor.lib
I read the Catalyst 6000 IDS Module has two PCI NICs: the first one for monitoring, and the other one for management.
Are the NICs only provided with "copper adapter", or could they be provided with "optical adapter" too?
Thanks a lot ;-)
Igor Lib
wkho
They are internal to the blade. It is not an external NIC. Two ports will show up on the module if you do a sho mod. The first port is the "capture" port and the second port is the "management" port.
