Redundant path
Lavanholy
1. One of my customer is having two
offices,that is site A and Site B.
2. Both sites are equiped with Cisco
router with WIC-1T card,and
connected by means of 512 KB leased
line.
3. Each site router is also connected
to a internet through a Cisco PIX 525
firewall (1MB DSL Ineternet
connectivity)
4. Site to Site IPsec has been
configured between sites.
5. Customer requirement is Site A
should access the Site B network
through the leased line
(512 KB which is primary)
6. If at any point of time if the leased line is down ,then traffic should go through the fast ethernet of the router ,through PIX525,which is already configured with Site-to-site IP sec .
How to achive this.
My solution:
1. I will configure the router with two static rout with different metric,that is through the leased line is metric 1,if the leased line fails,then the second static route is through the fast ethernet with the different metric 5.
If I am right please suggest me what would be the effect.
If I am wrong what is the alternate?
Please suggest me the solution.
Thanks and Regards,
S.Venkataraman.
Danilo Dy
1. Primary
Router = A & B
Link = 512Kbps Leased Line
Routing = Default administrative distance
2. Redundant/Backup
Pre-requisite = Create IP GRE Tunnel between router A & B thru PIX/IPSec/Internet
Routing = Higher administrative distance
This is called floating static route. Doing the above, you will have auto-failover.
Dandy
Hi Dandy,
Thanks for the info.Please send me some sample configuration it would be great helpful for me.
Thanks and Regards,
S.venkataraman.
Wouldn't it be easier to just have dynamic routing over the leased line and a static default route to the local PIX on each router? If the leased line goes down the router should lose its route over the leased line and use default route.
