split tunneling vs 3005 concentrator
ydaigneault
I want to enable split tunneling with allowing network in list to bypass tunnel with the default client local lan access in one of the group configure created on the unit. But the allowing network... box remains grayed out?
any ideas?
regards, Yves Daigneaut.
ajagadee
Have you checked the option Tunnel Everything and then tried to configure "Allow the networks in list to bypass the tunnel". If this is the case, then the option should not be grayed out.
In an Allow Networks in List to Bypass Tunnel configuration, The IPSec client uses the network list as an exclusion list: a list of addresses to which traffic should be sent in the clear. All other traffic is routed over the IPSec tunnel.
Arul
Hi Arul,
yes I did, I opened a case with the TAC and it seems to be a corrupted config file... They will try to reproduce the problem in their lab...
thanks, Yves.
If you dont mind, keep the group updated with the solution provided by TAC.
Arul
