sysopt connection enforcesubnet command
chan-kuen.hui
Dear All,
In version 6.0 or later "sysopt connection enforcesubnet" command have been removed.
Is these command or feature already included in the IOS? also, is there any document mention this?
Thanks.
CK
scoclayton
Level 7
Level 7
Documentation that the command has been removed:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v53/relnotes/pixrn53.htm#xtocid18
The "sysopt connection enforcesubnet" has been replaced by "ip verify reverse-path ":
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/gl.htm#wp1137904
Effectively, the 2 commands work the same. The newer command is more in keeping with the way Cisco IOS handles the situation.
Hope this helps.
Scott
Is "ip verify reverse-path " a default command?
Thanks.
CK
No, you need to enable it.
Scott
