Verifying CoPP violation
Junior19
Hi All,
Greeting!
I'm trying to test out the CoPP violation on C9600 switch.
By this guide,
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/softwasimire/release/16-11/configuration_guide/sec/b_1611_sec_9600_cg/b_1611_sec_9600_cg_chapter_0101000.html
I understand that policing rate can be modified. However, I couldn't think of and find out how to simulate and verify the violation.
There are 21 Class-map in total and I'd like to test out to reach the violation.
Any pointers, documents and posts to be would much appreciated.
Junior
11 Replies 11
balaji.bandi
i had downloaded some time i was reading some site I found over the internet  for CCNP
check the attachment for reference :
BB
@balaji.bandi
I've found that document and read through it. As far as I understand, it is implementing own ACLs class-maps along with policy map and set it onto CoPP. In this case, I realized it will obviously hit the exceeded as long as I set minimum. I think that case is different from mine.
Thanks for the pointer anyway. If you have more thoughts on this, feel free to let me know.
Best,
Switch(config-pmap-c)#police rate 10 pps  <<- first assign low pps then ping to interface of SW, you will see some packet drop
Junior19
@MHM Cisco World
ICMP traffic cpu queue is related to class system-cpp- police-data.
default parameter as follows;
class system-cpp-police-data
police rate 750 pps
when I assign it to 10 pps, the min pps allowed to set for this value is 250 pps. Then while pinging successfully from another box, I collect the show policy-map contorl-plane, it does not even hit the conformed bytes.
C9606R_CS01(config-pmap-c-police)#do sh policy-map control-plane | i Class-map|conformed|exceed
Class-map: system-cpp-police-ios-routing (match-any)
conformed 4402238 bytes; actions:
exceeded 0 bytes; actions:
Class-map: system-cpp-police-ios-feature (match-any)
conformed 61458 bytes; actions:
Class-map: system-cpp-police-data (match-any)
conformed 0 bytes; actions:
Any idea would be much appreciated.
Best,
that OK,
only do ping with repeat 1000 and check the drop
I did ping repeat 100000. No dropping on ping as well as no hitting on class. And I wonder how to ping or how to make to hit the class, at least to see conformed bytes.
exceeded 0 bytes; actions: <<- add action drop to control plane and check again
@MHM Cisco World sorry for my delay response. I was a bit under weather for some days.
actually. actions: drop has been configured by default. my previous output was taken by filter. Here is complete default config.
Control Plane
Service-policy input: system-cpp-policy
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: none
police:
rate 16000 pps, burst 3906 packets
conformed 28937588 bytes; actions:
transmit
drop
0 packets, 0 bytes
Match: none
police:
rate 6000 pps, burst 1464 packets
transmit
drop
0 packets, 0 bytes
Match: none
police:
rate 250 pps, burst 61 packets
transmit
drop
Class-map: system-cpp-police-sys-data (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-sw-forward (match-any)
0 packets, 0 bytes
Match: none
police:
rate 1000 pps, burst 244 packets
conformed 78 bytes; actions:
transmit
drop
Class-map: system-cpp-police-multicast (match-any)
0 packets, 0 bytes
Match: none
police:
rate 500 pps, burst 122 packets
transmit
drop
Class-map: system-cpp-police-multicast-end-station (match-any)
0 packets, 0 bytes
Match: none
police:
rate 2000 pps, burst 488 packets
conformed 256 bytes; actions:
transmit
drop
Class-map: system-cpp-police-punt-webauth (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-l2-control (match-any)
0 packets, 0 bytes
Match: none
police:
conformed 7059268 bytes; actions:
transmit
drop
Class-map: system-cpp-police-stackwise-virt-control (match-any)
0 packets, 0 bytes
Match: none
police:
rate 8000 pps, burst 1953 packets
transmit
drop
Class-map: system-cpp-police-routing-control (match-any)
0 packets, 0 bytes
Match: none
police:
rate 5500 pps, burst 1342 packets
transmit
drop
Class-map: system-cpp-police-system-critical (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-l2lvx-control (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-topology-control (match-any)
0 packets, 0 bytes
Match: none
police:
conformed 21878320 bytes; actions:
transmit
drop
Class-map: system-cpp-police-dot1x-auth (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-protocol-snooping (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-dhcp-snooping (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-forus (match-any)
0 packets, 0 bytes
Match: none
police:
rate 4000 pps, burst 976 packets
conformed 61124 bytes; actions:
transmit
drop
Class-map: system-cpp-default (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-high-rate-app (match-any)
0 packets, 0 bytes
Match: none
police:
rate 13000 pps, burst 3173 packets
transmit
drop
Class-map: system-cpp-police-ewlc-control (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Any idea?
Best,
Junior
I will try lab this case and I will share result with you.
I got conformed packet hits on system-cpp-police-data. I made the C9600 to generate the ICMP destination host unreachable.
On a device, I set c9600 IP as gateway. ping from a device to unreachable host so as to get C9600 to generate the ICMP destination host unreachable. If I can generate this kind of process with a high performance box, reducing the police rate to min 250 pps, I think it might hit the exceeded.
0 packets, 0 bytes
Match: none
police:
rate 750 pps, burst 183 packets
conformed 107973 bytes; actions:
transmit
drop
Again, I still need to figure out which kind of packet/process needed to hit conformed at least for the other policy/class.
Best,
ping <SVI of any VLAN>  count 1000 packet-size 800
CoPP will act only to traffic designated to CPU (any IP assign in SW)
Verify Control Plane Policing Violations on Nexus Platforms - Cisco
