VPN3015 and NETBIOS
dstihler
Hello: Is there a way to see the resources in network neighborhood after authenticating to the VPN 3015? We are using SecurID Cards for authenticating into the VPN.
Or, do you have to authenticate to the WindowsNT Machine and use WinNT as your security manager by passing off login from the VPN to WinNT.
wukunpeng
In order to broadcast netbios to another ip subnet,you can use "ip helper-address" command.,it will auto open 8 udp ports(69,53,37,137,138,67,68,49),you can use "ip forward-protocol" command to close them,or open another tcp/udp port.
IPsec is a standard,you can use ipsec client for NT
