WebVPN Does Not Work in Load Balancing
dianewalker
I have two 3005 VPN Concentrators. Load Balancing works with VPN Client. However, it does not work with WebVPN. When I typed the Virtual Cluster Master IP address in the Internet Explorer, I got the message: "Page cannot be displayed" The WebVPN works with the IP address of either VPN Concentrator. Do you have any suggestions? Thanks.
umedryk
Level 5
Level 5
You should use VRRP in the concentrators for load balancing...
Thanks for your response.
VRRP does not do Load Balancing. VRRP only does fail-over. Anyway, are you saying that Load Balancing does not work in WebVPN and only VRRP would work in WebVPN? If that is the case, please let me know so I can make a change. Thanks.
