I'am trying to find out actual power consumption on c7600 routers.
When issusing comman "show power used":
7606#show power used
system power used = 1736.28 Watts (41.34 Amps @ 42V)
7606#
router don't show actual power consumption, it shows sum of all power allocated for each of the module in router... Even for redundant SUP/RSP even if it is not in router.
On ASR9k, I can see exact power consumption on each power module:
RP/0/RSP0/CPU0:asr9010#admin show environment power-supply
Wed Jul 30 13:30:11.200 CETDST
R/S/I Modules Capacity Status
(W)
0/PM0/*
host PM 1500 Ok
0/PM1/*
host PM 1500 Ok
0/PM2/*
host PM 1500 Ok
R/S/I Power Supply Voltage Current
(W) (V) (A)
0/PM0/* 346.8 54.2 6.4
0/PM1/* 434.4 54.3 8.0
0/PM2/* 421.9 54.1 7.8
Total: 1203.1
Is there any way to find out actual consumption on 7600 in similar way as on ASR9k?
The same question stands for ASR9000V satellites!
