[Cisco FAQ] - My D9854 receiver does not give me HD/SD SDI out.
Rajat Gupta
What could be the issue?
Joseph Wojtczak
The output ports M1/M2 factory defaulted to ASI, if you need SDI you will need to change the output format.
From the front panel  press Menu then select Setup, then Outputs. On the Output Menu select M1/M2 and change the port you are using to SDI.
Joseph Wojtczak
