Hi Everyone, Would like to extend my thanks in advance for anyone offering assistance. As the subject hints, anyone here know of a way to convert IOS configs to XR config? I seen and heard about SOX tool but i am unable to find it. I also tried ...
view more
When I run the command 'sh controllers fabric fia q-depth location 0/0/CPU0' or any 0/X/CPU0 and see the following, what exactly does it mean? RP/0/RSP0/CPU0:Router#sh controllers fabric fia q-depth location 0/0/CPU0********** FIA-0 **********Categor...
view more
Symptoms: the root password can't log in by GUI Solution:1) login CLI as admin2) write command "ncs webroot enable" without qutations3) we can check the status by "ncs webroot status" hope this will help someonethanks
Introduction
ISO images are as close as we can get to the old school classic IOS images from back in they day.
Doing upgrades by putting a new image on the flash, changing the boot pointer and reload was and is still the walhalla of Cisco based devices.
view more
Hi , i have installed IOS XRv9000, and enabled BNG inside it .. How i can add the number of subscriber session in PRTG ..is there any OID or MIB supported by XRv9000 Kind Regards
