DFC problem
Can some one help me, i have the next log appear in my 7600-S
Jul 21 07:26:29: %EARL_L2_ASIC-DFC2-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0EBD
Jul 21 07:36:19: %EARL_L2_ASIC-DFC2-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0EBD
Jul 21 07:49:17: %EARL_L2_ASIC-DFC2-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0EBD
Jul 21 08:10:48: %EARL_L2_ASIC-DFC2-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0EBD
Jul 21 08:17:09: %EARL_L2_ASIC-DFC2-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0EBD
Jul 21 08:32:32: %EARL_L2_ASIC-DFC2-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0EBD
I search a lot about this message and i can't find anything
bhnegi
Generally this message usually means there is a communication problem between the SUP and one of the line cards.
https://supportforums.cisco.com/discussion/10454461/earll2asic-sp-stdby-4-dbushdrerr-earl-l2-asic-0
Is this ES20 module by any chance? There was  a known bug below
CSCso12121    %EARL_L2_ASIC-DFC4-4-DBUS_HDR_ERR on 7600 with ES20G module
Externally found moderate (Sev3) bug: R-Resolved
If it is a non-ES20 card try reloading/reseating the module and try it on a different slot. If none works I would suggest replacing it.
Best Regards,
Bheem
bhnegi
Best Regards,
Bheem
Thanks for you help Bheen, I'll do the upgrade of IOS and will warn you if it works
Regards.
