GNS3 lab route-leaking not working
vasialexandru43
Hello all,
I'm trying to do a lab in gns3 where I have some routers one is CE4 and one is PE2,I want to advertise the loopback 11 of PE2 to CE4 that resides on vrf C1 and is not working. I paste here the config on PE2 and CE4 maybe I did something wrong:
CE4#show run
Building configuration...
Current configuration : 1679 bytes
! Last configuration change at 10:28:09 UTC Sat Jun 10 2023
version 16.8
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform console serial
hostname CE4
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
subscriber templating
license udi pid CSR1000V sn 9TQ4BJSOOUO
no license smart enable
diagnostic bootup level minimal
redundancy
interface Loopback0
ip address 10.16.11.11 255.255.255.0
interface GigabitEthernet1
ip address 101.2.22.30 255.255.255.224
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet2
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet3
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet4
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
router bgp 100
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 101.2.22.1 remote-as 200
address-family ipv4
network 10.16.11.0 mask 255.255.255.0
neighbor 101.2.22.1 activate
exit-address-family
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
logging synchronous
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
PE2#show running-config
Current configuration : 2189 bytes
! Last configuration change at 10:28:12 UTC Sat Jun 10 2023
version 16.8
hostname PE2
boot-start-marker
boot-end-marker
vrf definition C2
rd 200:1
route-target export 20:20
route-target import 30:30
address-family ipv4
exit-address-family
no aaa new-model
no ip domain lookup
license udi pid CSR1000V sn 9N0LYWUTOZK
redundancy
interface Loopback0
ip address 10.19.3.33 255.255.255.255
interface Loopback11
ip address 10.1.1.1 255.255.255.0
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
vrf forwarding C2
ip address 101.2.22.1 255.255.255.224
negotiation auto
no mop enabled
no mop sysid
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
router bgp 200
address-family ipv4 vrf C2
redistribute connected
redistribute static route-map Global-to-Vrf
neighbor 101.2.22.30 remote-as 100
neighbor 101.2.22.30 log-neighbor-changes
neighbor 101.2.22.30 activate
neighbor 101.2.22.30 advertise-map Global-to-Vrf exist-map Global
exit-address-family
ip http server
ip prefix-list Global seq 5 permit 10.1.1.0/24
route-map Global-to-Vrf permit 10
match ip address prefix-list Global
set ip next-hop 101.2.22.1
control-plane
line con 0
logging synchronous
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
CE4#show ip ro
CE4#show ip route b
CE4#show ip route bgp
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
Harold Ritter
Hi @vasialexandru43 ,
1. To import routes from the global routing table to the VRF you need to apply the following command under the VRF configuration:
vrf definition C2
address-family ipv4
import ipv4 unicast map Global-to-Vrf
2. Remove the "set ip next-hop 101.2.22.1" from the route-map.
3. Remove the following configurations statement from the VRF.
router bgp 200
no redistribute static route-map Global-to-Vrf
no neighbor 101.2.22.30 advertise-map Global-to-Vrf exist-map Global
4. You also need to originate the loopback address in the global BGP table so that it can be imported in the VRF.
router bgp 200
address-family ipv4
network 10.1.1.0 mask 255.255.255.0
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
vrf definition C2
address-family ipv4
router bgp 200
router bgp 200
address-family ipv4
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
@Harold Ritter Thank you so much for this it really helped me to fix it !
Can you ping between two IP ?
You are very welcome @vasialexandru43 and thanks for the feedback
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
