IGMP Timeout problem ????
Tomasz Hinz
I have problem with Nexus 3064. I would like to send statically multicast to Cisco 3550 switch.
I configured PIM router both on Nexus and 3550 switch.
n3k (sender)
interface Vlan2241
 ip address 172.29.0.13/30
ip pim sparse-mode
ip igmp static-oif 239.254.1.1 source 172.30.1.1
ip igmp static-oif 239.254.1.2 source 172.30.1.2
ip igmp static-oif 239.254.1.3 source 172.30.1.3
ip igmp static-oif 239.254.1.4 source 172.30.1.4
c3550 (receiver)
interface GigabitEthernet0/0.2241
encapsulation dot1Q 2241
ip address 172.29.0.14 255.255.255.252  ip pim sparse-mode
When checking mroute table on c3550 (receiver) – is ok, multicast arrives.
#sh ip mroute summary
IP Multicast Routing Table Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.254.1.1), 00:00:24/stopped, RP 172.29.0.14, OIF count: 0, flags: SP
     (172.30.1.1, 239.254.1.1), 00:00:24/00:02:35, OIF count: 0, flags: PT
(*, 239.254.1.3), 00:00:24/stopped, RP 172.29.0.14, OIF count: 0, flags: SP
     (172.30.1.3, 239.254.1.3), 00:00:24/00:02:35, OIF count: 0, flags: PT
(*, 239.254.1.2), 00:00:24/stopped, RP 172.29.0.14, OIF count: 0, flags: SP
     (172.30.1.2, 239.254.1.2), 00:00:24/00:02:35, OIF count: 0, flags: PT
(*, 239.254.1.4), 00:00:24/stopped, RP 172.29.0.14, OIF count: 0, flags: SP
  (172.30.1.4, 239.254.1.4), 00:00:24/00:02:35, OIF count: 0, flags: PT
(*, 224.0.1.40), 00:30:45/00:02:33, RP 0.0.0.0, OIF count: 1, flags: DCL
When the timeout counters end (here you can see 0:02:35) multicast doesn’t work, does not help anything - I have to disable and enable interface .
I expect, when I start send multicast it is going continuously, no matter if the client sends IGMP query or not.
********************************* Comel - Tomasz Hinz
0 Replies 0
