Ip input high cpu using ip pim sparse mode
hello all, I have a problem and I can not resolvover,
when you configure an interface with ip pim sparse-mode to enable multicast, IP INPUT and IPC Seat Manager process also increases and processor consumption
i have a 7609-S witch supervisor RSP720-3C-GE with IOS
(c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE5
interface GigabitEthernet9/2
description Conectado a Fdo de la Mora
mtu 9216
ip address 201.217.63.11 255.255.255.254
logging event link-status
ip pim sparse-mode
load-interval 30
mpls ip
mpls mtu 8992
here is the show proce cpu:
CPU utilization for five seconds: 72%/24%; one minute: 71%; five minutes: 67%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   2        1136      404870          2  0.00%  0.01%  0.00%   0 Load Meter
   7     6603016      480257      13748  0.00%  0.28%  0.29%   0 Check heaps
  29     1885252    19109009         98 13.75% 13.23% 12.65%   0 IPC Seat Manager
  45      158832     1627879         97  0.07%  0.00%  0.00%   0 EnvMon
  81      231196     4632717         49  1.11%  1.04%  1.01%   0 IPC LC Message H
  86      650644     4182873        155  5.11%  4.90%  4.69%   0 MRIB RP Proxy
  88      614384     1574748        390  0.00%  0.01%  0.00%   0 Compute load avg
  89      405288       34389      11785  0.00%  0.02%  0.00%   0 Per-minute Jobs
  91        1176     5569028          0  0.07%  0.02%  0.00%   0 IGMP Input
100        1760    11526224          0  0.07%  0.07%  0.07%   0 PIM Process
101          92     5433233          0  0.07%  0.02%  0.00%   0 Mwheel Process
103      160132     3666065         43  1.11%  0.99%  0.96%   0 MRIB Trans
106         388    27130072          0  0.07%  0.08%  0.07%   0 MFIB_mrib_write
107      449264     3652275        123  3.19%  2.99%  2.89%   0 MFIB_mrib_read
188        1028    63725836          0  0.07%  0.03%  0.02%   0 ACE Tunnel Task
220        1000    63107906          0  0.00%  0.04%  0.02%   0 IP ARP Retry Age
221   124781224  3165557742         39  8.71%  8.62%  8.24%   0 IP Input
255         144     7905897          0  0.07%  0.00%  0.00%   0 Ethernet Timer C
256        3516   252232511          0  0.15%  0.15%  0.15%   0 Ethernet Msec Ti
260        1096    63107933          0  0.07%  0.02%  0.01%   0 IPAM Manager
275      678364     6457906        105  5.59%  5.32%  5.11%   0 const-mfib-rp Pr
300     2051268     4844327        423  9.03%  9.02%  8.44%   0 XDR mcast
312        5540      771831          7  0.00%  0.02%  0.00%   0 CDP Protocol
316       10880     2394171          4  0.00%  0.01%  0.00%   0 CEF: IPv4 proces
377      811328     1012179        801  0.00%  0.05%  0.05%   0 HIDDEN VLAN Proc
487         304    11239039          0  0.07%  0.01%  0.00%   0 PM Callback
488     3526840    50850725         69  0.00%  0.31%  0.31%   0 Port manager per
549      615276       87315       7046  0.00%  0.03%  0.00%   0 BGP Scanner
0 Replies 0
