Subscriber Manager Times-Ten problem
aquafon123
Hey guys,
I'm trying to install the subscriber manager on a testing environment, using a Linux virtual machine; and after going theough the process I'm having this error massage that I couldn't find a soulution for, so I need help
thank you in advance
[pcube@su-scesm-test bin]$ ./p3sm --sm-status
SM is running.
SM operational state is Failure
Errors/warnings -  during SM startup:
Error - Times-Ten DB is not set up correctly:
[TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0836: Cannot create data store shared-memory segment, error 22 -- file "db.c", lineno 7787, procedure "sbDbCreate"
1) Error: [TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0836: Cannot create data store shared-memory segment, error 22 -- file "db.c", lineno 7787, procedure "sbDbCreate", sqlState: 08001, errorCode: 836 [TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0836: Cannot create data store shared-memory segment, error 22 -- file "db.c", lineno 7787, procedure "sbDbCreate"
2) Error occured while validating configuration: SMM:name=SMM: java.lang.NullPointerException
Use "--reset-sm-status" option in order to reset the errors.
Command terminated successfully
mirsad001
If you haven't found out already, the solution is to increase the shared memory maximum segment size. It is located in /etc/sysctl.conf....
Example:
#  ---- Begin settings for TimesTen
kernel.sem = 250 32000 100 100
kernel.shmmax = 536870912
#  ---- End of settings for TimesTen
Change to:
kernel.shmmax = 1073741824
Reboot the machine and the problem should be solved!
