Duo for SSH client tools?
dianawinsky
Can we use DUO MFA/2FA for SSH client tools such as PuTTY, etc.? I see the Unix application guide, but is the SSH client tools part of that guide?
DuoKristina
You use PuTTy and similar tools to SSH to some remote *nix system. You install Duo Unix on that remote system, and when you connect to it using PuTTy or whatever ssh client, you go into the 2FA logon flow.
Duo, not DUO.
DuoKristina
Duo, not DUO.
