DUO Hardware Token Battery
i have a customer that has purchased a set of DUO Hardware Tokens.
I have not found anywhere that it specifies the expected Battery Life of a Token.
Can anyone point me to a document thta might answer the question?
DuoPablo
Hi Richard,
While the battery life is projected to be 7 years, Duo only guarantees 6 months via warranty. Generally, the token battery should last for a minimum of two years.
Please Note: The battery is not replaceable as this would cause tampering with the device and make it insecure.
For more information regarding Duo D-100 hardware tokens, please contact Duo Support
Hope this helps!
DuoPablo
Hi Richard,
Hope this helps!
