Failed Upgrade SG350 20-Port from Firmware v2.5.5.47 to v2.5.9.15
indianajones111
I own a SG350-Port 20 Managed Switch.  I recently upgrade my firmware from v2.5.5.47 to 2.5.9.15, with the firmware itself, allowing me to log back into the device.  However, after the upgrade, my network stopped working.  After reloading my startup-config.txt and rebuilding from scratch, I cannot get my old configuration of my VLANs to run.  In addition, the port utilization stays at 0%.  I use a Firewalla Gold to manage my DHCP/IP addresses.  This has worked before this upgrade.
Here is a copy of my startup-config.txt below.  What am I doing wrong?
config-file-header
CiscoSwitch
v2.5.5.47 / RTESLA2.5.5_930_364_286
CLI v1.0
file SSD indicator excluded
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 10,20,30,40,50,60,70
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
loopback-detection enable
link-flap prevention disable
bonjour interface range vlan 1
qos advanced
policy-map "QoS Policy"
exit
hostname CiscoSwitch
logging host 192.168.46.183 port 513 facility local1
logging aggregation on
username rhettsaunders password encrypted ec43f3abffe97977628675dcaaf26985386889f3 privilege 15
ip ssh server
snmp-server server
snmp-server engineID local 80000009033c57312b66c3
snmp-server location "Maintenance Closet"
snmp-server contact "Rhett Saunders"
snmp-server filter ifMIB iso included
snmp-server filter ifMIB ifMIB included
snmp-server filter Transmission iso included
snmp-server filter Transmission transmission included
snmp-server filter "Interface Info" iso included
snmp-server filter "Interface Info" interfaces included
snmp-server community-group saunders saunders 172.24.1.122
snmp-server host 172.24.1.163 traps version 2c public
snmp-server group saunders v3 priv
snmp-server source-interface traps vlan 1
snmp-server source-interface informs vlan 1
no ip http server
clock timezone DEN -7
clock summer-time web recurring usa
clock dhcp timezone
interface vlan 1
name Default
interface vlan 10
name "Main Network"
interface vlan 20
name "Internet of Things"
interface vlan 30
name "Boys' Computers"
interface vlan 40
name "Laptops, Desktops & Printer"
interface vlan 50
name "Tablets & Smart Phones"
interface vlan 60
name Honeypot
interface vlan 70
name "Lorex NVR"
interface GigabitEthernet1
flowcontrol auto
description "Master Bedroom EAP"
spanning-tree link-type point-to-point
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 2-29,31-69,71-4094
macro description "switch "
!next command is internal.
macro auto smartport dynamic_type unknown
interface GigabitEthernet2
flowcontrol auto
description "Rec Room EAP"
switchport trunk allowed vlan 2-29,31-4094
interface GigabitEthernet3
flowcontrol auto
switchport protected-port
switchport trunk allowed vlan 2-9,11-19,21-29,31-39,41-49,51-59,61-69,71-4094
interface GigabitEthernet4
flowcontrol auto
description "Butlers Pantry EAP"
switchport access vlan 40
interface GigabitEthernet5
flowcontrol auto
description "Maintenance Closet Deco"
interface GigabitEthernet6
description "Bitdefender Box"
switchport access vlan 30
interface GigabitEthernet7
flowcontrol auto
negotiation preferred master
macro description switch
macro auto smartport dynamic_type switch
interface GigabitEthernet8
interface GigabitEthernet9
description "Family Room Netgear Switch"
switchport access vlan 20
interface GigabitEthernet10
description RussianBlue
switchport access vlan 10
interface GigabitEthernet11
description "Beastmaster NIC #1"
interface GigabitEthernet12
description "Beastmaster NIC #2"
spanning-tree disable
interface GigabitEthernet13
description "Beastmaster NIC #3"
interface GigabitEthernet14
description "Beastmaster NIC #4"
interface GigabitEthernet15
description "Lorex NVR"
switchport access vlan 70
interface GigabitEthernet16
description "Xfinity Modem Reset Device"
interface GigabitEthernet17
description "Firewalla NIC #3"
storm-control broadcast kbps 100000
storm-control unicast kbps 100000
storm-control multicast kbps 100000
switchport trunk allowed vlan 1-29,31-4094
interface GigabitEthernet18
description "Firewalla NIC #1"
switchport trunk allowed vlan 2-9,11-19,21-39,41-49,51-59,61-69,71-4094
interface GigabitEthernet19
interface GigabitEthernet20
exit
banner login
All actions are recorded.
banner exec
macro auto processing type host enabled
ip source-guard
monitor session 1 destination interface GigabitEthernet12 network
monitor session 1 source vlan 10
monitor session 1 source vlan 20
monitor session 1 source vlan 30
monitor session 1 source vlan 40
monitor session 1 source vlan 50
monitor session 1 source vlan 60
monitor session 1 source vlan 70
balaji.bandi
what is the reason for the upgrade, any bug fixes or cisco suggestions?
try resetting to the factory again with the latest firmware and testing it.
if not I will advise going back to the old firmware as working and raising the SMB tac case.
BB
Thank you BB for the swift response.  As a cybersecurity professional, I try to maintain the latest firmware upgrades to stay ahead of threat actors.  I will follow your instructions and see if that works.
