L2 and L3 in SG350-10P
Lukasz1977
HI All,
I would like to ask you where I can find the option to change my SG350-10P form L2 to L3 layer?
In SG300 switch it is in Administration/System Settings but if I wanna find it in my SG350-10P it is not there. Just to add I changed in my SG350 switch 'Display mode' form 'Basic' to 'Advanced'. Attached my screen.
Waiting for the feedback.
luis_cordova
Hi @Lukasz1977
Try this:
6 Replies 6
luis_cordova
Hi @Lukasz1977
Try this:
Will do.
Please give an answer why Tagged pots do not work in this switch. Even I want try to set it I can but after I save it I can not see Tagged working. Only Unttaged/Excluded
balaji.bandi
There is no Configuration required for 350/5XX series like 300,
they work both L2/L3 mode you need to just configure, check below video help you :
https://www.youtube.com/watch?v=NLMKwYSlQDY
BB
Will try to use it.
Please give an answer why Tagged pots do not work in this switch. Even I want to set it I can but after I save it I can not see Tagged ports working. Only Unttaged/Excluded is visiable.
