VPN picking up same IP L2TP Server
I have a VPN L2TP Server and more than 10 users have been created when I connect more than one user to the VPN they get the same IP and drop the connection another would I have to fix this VPN inside cisco RV340 ? or make some configuration on the machine ?
Did you configure address pool inside Cisco RV340? Check this solution below, I hope this can help you.
https://community.cisco.com/t5/routers-small-business/how-to-connect-to-rv340-on-windows-via-vpn/td-p/4105119
Raphael Pulchera
Problem when on the same network connects more than VPN drops the other
balaji.bandi
you mean to say if other user connected, exiting user disconnect ?
check the video setup and verification : dhcp
make sure you upgrade to latest firmware if any bugs fixed ?
Also check the License and logs when this occurs again
https://www.youtube.com/watch?v=aZwCrtoTYx0
BB
In this edition of Cisco Tech Talk, I'm going to create a client-to-site L2TP VPN using the RV340 and Windows built-in Client.
