11-30-2023 04:28 AM
I have a VPN L2TP Server and more than 10 users have been created when I connect more than one user to the VPN they get the same IP and drop the connection another would I have to fix this VPN inside cisco RV340 ? or make some configuration on the machine ?
12-30-2023 04:08 PM
Did you configure address pool inside Cisco RV340? Check this solution below, I hope this can help you.
Raphael Pulchera
01-08-2024 09:03 AM
Problem when on the same network connects more than VPN drops the other
12-30-2023 04:29 PM
you mean to say if other user connected, exiting user disconnect ?
check the video setup and verification : dhcp
make sure you upgrade to latest firmware if any bugs fixed ?
Also check the License and logs when this occurs again
