ā04-13-2012 06:13 AM - edited ā07-03-2021 09:59 PM
Having a problem wih intermec PM4i barcode printers with wireless network cards disassociating from a 5508 controller in a production plant, The printers have ip address that have a static IP address that is from vlan 2 ( wlan that the printers connect to) while the AP that they are connecting to the network is on vlan 201. The printer once connected will stay connected for about 1 hour then lose association, once they are powered cycle they come back up with the proper connections.
ā04-13-2012 05:31 PM
Do you have 802.11b low-speed data rates enabled?
Is your printer SSID broadcasting?
Are you using OPEN authentication?
ā04-14-2012 12:27 AM
Stacey:
- Were your printers working fine before? if yes; when the problem exactly started to appear?
- What are the APs model you have?
- Do your intermec devices have latest firmware? if not you can consider upgrading them to the latest.
- Why do your devices disconnect at the first place? is that because the session-timeout that is configured under your SSID? what is the configured session-timeout under your SSID?
- What is the code version you are running?
Amjad
