Can use the RP-TNC antenna type with Aironet 1532E by RP-TNC to N-Male plug ?
chuxuanvu
I'm using APs with two antennas per AP as:
AIR-AP1242AG-A-K9
802.11ag LWAPP AP Dual 2.4,5GHz RP-TNC ETSI Cnfg
AIR-ANT5195P-R
Cisco 5GHz 9.5dBi Patch Antenna w/RP-TNC connector
AIR-ANT2460P-R
Cisco 2.4 GHz 6 dBi Patch Antenna w/RP-TNC Connector
The reason I use antennas like this because of my environment, 5GHz source is in one direction and 2GHz is in another, the omni antenna type is not good enough. After many time site survey, try different antenna types, I found the above combination is best suite for me.
Because the Aironet 1242AG is end of sale,  I'm looking for the new model Aironet 1532E with capable support single-band antenna.
But when I see the directional antennas for 1532E, all using N-Male connector: http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1530-series/guide-c07-729725.html
Part Number
Frequency Band
Gain
Type
Required Quantity
AIR-ANT2547VG-N
2.4/5 GHz
4/7 dBi
Omnidirectional
AIR-ANT2547V-N
2.4/5 GHz
4/7 dBi
Omnidirectional
AIR-ANT2588P3M-N=
2.4/5 GHz
8/8 dBi
Directional
AIR-ANT2450V-N
2.4 GHz
5 dBi
Omnidirectional
AIR-ANT2480V-N
2.4 GHz
8 dBi
Omnidirectional
AIR-ANT2413P2M-N=
2.4 GHz
13 dBi
Directional
AIR-ANT5180V-N
5 GHz
8 dBi
Omnidirectional
AIR-ANT5114P2M-N=
5 GHz
14 dBi
Directional
It doesn't have a similar type as previous RP-TNC connector antenna. Example:
- The 2.4GHz 13 dBi Directional AIR-ANT2413P2M-N=: it got narrow angle than AIR-ANT2460P-R and I also don't need too much gain like that.
- The same situation for 5Ghz Directional
So, can I use the old RP-TNC antenna type with new Aironet 1532E by RP-TNC to N-Male plug like this: http://www.amazon.com/C2G-Cables-42201-N-Male-Adapter/dp/B001GUW2RW
Thank in advance,
Brett Verney
Hi there,
Indoor APs require RP-TNC connectors, outdoor APs require N-Type connectors. It would technically work; however I have been told that Cisco TAC would not support the configuration.
Alternatively, you could use 2 x Cisco 3702e or 1852e APs (with the older RP-TNC directional antennas) and have one AP dedicated for each band. You could disable the radio that you aren't using on each AP. Again, Cisco TAC would not support this setup.
-Brett
