Cisco Wireless Multicast Setup, One Subnet, To Enable Apple AirPlay
MrPrince1979
I’m having issues with enabling Apple’s AirPlay services on a relatively simple network consisting of a Cisco 881 (Advanced IP Services) and an autonomous Cisco 1142 AP. I’ve attached a diagram explaining the connectivity. I believe I have to enable IP Multicast at the router, but I’m not really sure the best/right way to do it. Also I’m not sure what/if any commands would be needed at the AP.
All of the wireless clients are confirmed to be in the same subnet, so no real routing is happening etc. Also regular Internet connectivity/routing from the wireless clients is fine.
Any help would be greatly appreciated. Thanks.
5 Replies 5
Scott Fella
There are other threads on this, but this one might help
https://supportforums.cisco.com/message/3520397#3520397
This will explain on the switch side:
https://supportforums.cisco.com/docs/DOC-24187
-Scott
Thanks for the two URLs. The first might be promising, but the second involves a WLC which I don't have. This is where I'm essentially getting stuck R.E. configs for both my wired 881 and my autonomous 1142.
The second link has a small section on the wired multicast side.
Scott Fella
Sent from my iPhone
-Scott
Here is another thread for the 1142.
https://supportforums.cisco.com/thread/2093036?tstart=0#3393570
Scott Fella
Sent from my iPhone
-Scott
I've tried the commnd [ no ip igmp snooping ] on the AP. Still nothing. I've also enables Multicast routing on the 881 using:
881(config)# ip multicast-routing
881(config-int vlan50)# ip pim dense-mode
Still nothing...
