Single wireless network(SSID) to broadcast on 2.4Ghz and 5Ghz radio
uuganbat.a
Hi, I have CISCO 1602 standalone access point, which has 2.4 and 5 radio and support to run on both radios. And I am trying to setup the two SSID, but first SSID to operate on both 2.4Ghz and 5Ghz radio, and second SSID to operate only on 2.4Ghz radio.
Is it possible to setup an SSID to operate on both 2.4Ghz and 5Ghz radio? Following are the config that I can think of, but not sure if it correct or not? Thank you.
Dot11 ssid one
Vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7
Mbssid Guest-mode
End
Dot11 ssid two
Vlan 2
authentication open
guest-mode
wpa-psk ascii 7
Mbssid Guest-mode
End
Int dot11 0
Mbssid
ssid one
ssid two
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
Int dot11 1
Mbssid
ssid one
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge group 1
interface Dot11Radio1.1
bridge group 1
interface FastEthernet0.1
bridge group 1
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge group 2
interface FastEthernet0.2
bridge group 2
Stephen Rodriguez
that should do it.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
uuganbat.a
Hi Stephen, Basically following command will turn on the SSID on 5Ghz radio? Is there any issues if you ran same SSID on both radio?
bridge group 1
How 802.11a/b/g/n capable wireless clients choose the band, will they flap between 2.4 and 5 band?
the bridging commands just allow the traffic to flow in the appropriate VLAN.
What allows the SSID under the Dot11Radio 1 is
ssid < blah >
that is what tells the radio what SSID to service.
As for how the client, it will choose by RSSI/SNR and what ever magic the vendor has used to determine which frequency to join.
HTH,
Steve
HTH,
Steve
