Adding a Analog Camera via a Analog Capture card on VSOM
sparklemotion
I have a VSOM/VSMS coresident on same box, and on back of the chasis it has a analog capture card.  I currently have 2 analog cameras that are functioning off of this card, I want to add another ( i belive it supports 16)  But when i try to  add a new camera on channel 3 of VSOM, it says (DB Error: No such field.)  Does the encoder card on the chasis have some kind of admin page i need to preconfigure for the third channel? if so what is the URL or setup for doing this?   Or am i just running into a VSOM bug.
Thanks in advance.
The VSOM Install & Upgrade Guide for 4.2.0 contains the required steps to upgrade the database schema
http://www.cisco.com/en/US/docs/security/physical_security/video_surveillance/network/operations_manager/4_2/install_upgrade/vsom_install.pdf
The final section of this document is entitled Upgrading VSOM.
Step 6 in that procedure deals with updating the database
Step 6
Upgrade the VSOM database in MySQL.
Enter the MySQL password when prompted. The default password is blank; press enter if there is no password.
If you are upgrading from Release 4.1.1 to Release 4.2.1:
shell> mysql -u root -p < /usr/BWhttpd/vsom/db/mysql-update-4.1.1-5_to_4.2.1.sql
If you are upgrading from Release 4.0.0 to Release 4.2.1, Run the following commands in sequence to upgrade the database:
mysql -u root -p < /usr/BWhttpd/bas/db/mysql-update-4.0.0-23_to_4.1.0.sql
mysql -u root -p < /usr/BWhttpd/bas/db/mysql-update-4.1.0-15_to_4.1.1.sql
mysql -u root -p < /usr/BWhttpd/bas/db/mysql-update-4.1.1-6_to_4.2.0.sql
mysql -u root -p < /usr/BWhttpd/bas/db/mysql-update-4.2.0-16_to_4.2.1.sql
In your case, you would begin with the step in bold above, and continue with the step below in order to arrive at a 4.2.0 schema.  It is always a good idea to backup your VSOM database before updating the schema.
Backing up VSOM
After configuring VSOM, you can back up the VSOM configuration.
Procedure
Step 1
Step 1
Step 2   Click Download.
Step 3  When prompted, save the .tar file to a secure directory.
The VSOM backup file is named VSOM__backup_timestamp. For example, VSOM_PST_backup_20070327153851.tar.
In a web browser, open http:///vsmc.html and navigate to the Encoding Server Backup on the Console page.
jfiranzi
The error you describe sounds more like a database error than something to do with the encoder.  Did you recently upgrade your VSMS/VSOM version?
From a console or ssh session, please issue the following command (after the # prompt) and cut/paste the results:
#  rpm -qa | grep -i cisco
#  /etc/init.d/mysql status
# mysql
mysql> use bas;
mysql> select * from bas_settings;
Then look on line id 12, "DB_VERSION"
You may possibly have a database schema which was not properly updated when upgrading VSOM.
I hope that helps...
It looks like it is the wrong version, where do I go from here ?
Cisco_VSMS-6.2.0-15d
Cisco_VSDocs-6.2.0-15d
Cisco_VSOM-4.2.0-12
Cisco_VSTools-6.2-15
Cisco_VSRecorder-6.2.0-15d
Cisco_VSES-6.2.0-15d
Cisco_VSBWT-6.2.0-16d
Cisco_VSVM-6.2.0-15
Cisco_VSDrivers-6.2.0-15d
Cisco_VSBase-6.2.0-15d
12 | DB_VERSION               | Application Database Version                                                        | 4.1.0-15
Step 6
Backing up VSOM
Procedure
Step 1
Step 1
worked like a charm thanks!
