Bosch Camera Compatibility with VSOM 7.7
henry.neciosup
Hello
My end-customer has MIC-7230-PB4 (MIC 7000) cameras.
This camera is not supported model in VSOM 7.7. Can I force to deploy this camera into VSOM 7.7 by using other camera model driver?.
http://www.cisco.com/c/en/us/td/docs/security/physical_security/video_surveillance/network/vsm/release_notes/7_7_0/vsm_rn_7_7_0.html
Henry
Scott Olsen
Level 6
Level 6
Hi Henry,
You *might* be able to provision these cameras and get them operational using the ONVIF device support, but YMMV.  I haven't had much luck in getting Cisco VSM to speak ONVIF (successfully) with endpoints that are otherwise compliant.
According to the 7.7 Release Notes, you won't get Video Motion Detection, but you should get PTZ control.
Best of luck!
Scott.
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
