Camera 2500: False Motion Detection every 60 sec
warichet.r
I've 2x2500 camera, both exibit the same behaviour: every 60 sec, there is a kind of refresh of the image, the pictures becomes slightly blue for 0.5sec.
This behaviour is very anoying as it triggers false Motion Detection.
Camera 1 is monitoring a front door in a hall at 3.5m, hence the sensitivity for the Motion Detection feature is very low (almost null), and the "refresh" doesn't trigger a false Motion Detection. Works fine.
Camera 2 is monitoring an acces way at a distance, the sensitivity has to be set-up at 3/4 of the range to trigger a real motion, but this triggers also false Motion Detection at each "refresh". The "refresh" occurs exactly every 60 sec, so I thought a parameter might have the wrong setup, but tried all I could reasonably do.
Lately, I've upgraded the FW to 2.4, lo luck
Any hint, please ?
Raymond
mpyhala
Level 7
Level 7
Hi Raymond,
Please post your question at the following page. The 2500 is not a Small Business camera.
https://supportforums.cisco.com/community/netpro/security/physical-security
Hi Raymond,
I moved your discussion into the area that Martin suggested so that you don't have to repost.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
warichet.r
Anyone having a 2500 camera ? preferably in Europe (PAL/50HZ)
If yes, could you watch the picture for a minute or two, please, and see if there is a kind of "blue refresh" every 60 sec ?
I'd like to determine if the problem is specific to all 2500 (generic) or has to do with my particular installation setup (specific).
Both cameras are identical (Ethernet cable, no Wi-Fi), fed from PoE on same switch, parameters are almost the same. Difficult to start some troubleshooting.
