Can the camera CIVS-IPC-2935 be installed on the wall mount bracket CIVS-IPCA-1011?
Matrework
Hallo!
I have a question: can the camera CIVS-IPC-2935 be installed on the wall mount bracket CIVS-IPCA-1011=, and сan it be powered from the CIVS-IPCA-PWR12V= (cable CIVS-CAB-BCE)?
Thx!
Matrework
Hi Konstantin,
Thank you for contacting Cisco Partner Helpline.
My name is Lynzie, I will be assisting you with case <00525248> regarding your inquiry about the compatibility of the CIVS-IPCA-1011= and CIVS-IPCA-PWR12V= with the CIVS-IPC-2935.
I went ahead and checked with our internal resources and I was advised that the CIVS-IPCA-1011= is compatible with the CIVS-IPC-2935.
Unfortunately the CIVS-IPCA-PWR12V= is not compatible with the CIVS-IPC-2935. The CIVS-IPC-2935 uses 24 VAC or 24 VDC power.
CIVS-IPC-2935
Outdoor Pendant, Clear Dome, PAL, 35x, SD PTZ IP Camera
List Price: USD  4,900.00
CIVS-IPCA-1011=
Wall mount, use with CIVS-IPCA-1010, 2500, 26xxV Dome series List Price: USD 50.00
CIVS-IPCA-PWR12V=
Cisco IP Camera Power Supply
List Price: USD 60.00
Please reference these links:
Cisco Video Surveillance 2900 IP Camera User Guide Installation
http://www.cisco.com/en/US/docs/security/physical_security/video_surveillance/ip_camera/2900/user_guide/ch01.html#wp1073728
Cisco Video Surveillance 2900 Series IP Cameras Compare Models http://www.cisco.com/en/US/partner/products/ps11252/prod_models_comparison.html#~accessories
Konstantin,
while the answer provided by the Partner Helpline is not wrong, it requires a clarification.
While you can use CIVS-IPCA-1011 wall mount, you will still need a threaded pipe with 3/4-in. thread on one and 1.5-in thread on the other side. This part is not available through Cisco though.
Another alternative is to use wall mount with 1.5-in thread, i.e. Pelco SWM-GY or IWM-GY.
Gregor
