CIVS-IPC-4500
Currently our company is testing two Cisco's cameras.
First one, CIVS-IPC-2500, is fine. Second, CIVS-IPC-4500, is not.
First of all, only IE and FF can get trough login page, but Chrome can't -- after click to Login button, Chrome goes to login page, again and again.
I don't believe that anything is wrong with Chrome.
Secondly, if click to View Video on the web client, error arise about wrong version of .NET SDK (http://j.mp/dDoDX9), however IE8 shows something else (http://j.mp/9Dez9W).
I do believe that issue is firmware. Current version of it is 1.0.1 (http://j.mp/9FGG7F). Attempt to download it from Support just failed.
Could anyone be so kind to help with it, please?
33 Replies 33
What you're saying here, ive tried it over a 100 times without luck.
I have VSM 6.2.1 on an ISR 2911 SRE. I am also unable to upgrade it to the latest version of 6.2.2 (for the ISR only)
But the problem is not in the software as i am accessing the IP Camera interface directly.
HumanTorch
Level 5
Level 5
tried the VLC thing, didnt work at all
The VLC suggestion was in response to Jie's reply (I have never tried using VLC with SRTP, only RTSP)
For a camera with IP address 192.168.1.104 for example, first log into the camera web interface via IE, authenticating as admin with a password (or another logon with at least view priviledges), and click on View Video.  In the address bar, you will see something like the following:
http://192.168.1.104/viewvideo.cs?version=1.0&sessionID=69389175&action=get
In order to establish the stream in VLC, you would need to use
rtsp://192.168.1.104/StreamingSetting=?version=1.0&action=getRTSPStream&sessionID=69389175
&ChannelID=1&ChannelName=1
That should permit viewing Channel 1 from the camera.  If you close the IE browser session, you will likely lose video through VLC (unless you are using multicast.)
I use the latest version of VLC.
I hope that helps,
Jim
artarmstrong
I realize this is an old post, but it is very similar to the problem I'm having.
I'm trying to stream a Cisco CIVS-IPC-4500. After much trial and error I am able to view stream on a PC using XP SP3 with IE6.0. It works, but I wouldn't call it reliable. I'm trying to stream using VLC, with hopes of eventually recording the stream.
I've used Wireshark to pull session ID from the stream to the XP machine.  However after trying several variations of the URL so far am unable to stream to VLC. Does Cisco provide documentation for proper syntax? I know from using the pwc2300 the manual is much more detailed. The URL I've used that appears like it should work is "rtsp://10.10.1.101:554/StreamSetting?version=1.0&SessionID=29262419&action=getRTSPStream&ChannelID=1&ChannelName=Channel1&EncoderPort=0 RTSP/1.0"
Does anyone have experience using VLC to stream from the 4500? Any suggestions?
Any ideas would be greatly appreciated. By spec this looks like a great cam, so far it seems very finicky, and hardly worth
Using it as it is now.
