02-20-2014 02:21 AM
I got an issue with upgrading IP camera firmware for 6000P Camera from 1.1.4 to 1.4.1 I am getting "bad Magic number" I appreciate if anyone could advise what does it mean?
Regards,karim
Solved! Go to Solution.
02-20-2014 07:05 AM
I had this same issue. TAC provided the following instructions...
Failed upgrade is a known defect, CSCuh97615
Symptom:
Firmware upgrade fail with non-default camera model name with the error message "bad magic number".
Conditions:
If user changes camera device name in basic page to anything other than the default camera model name
Workaround:
Revert the camera device name to the default camera model name and then do upgrade.
This issue is resolved in 1.2.1-73 and later versions of the firmware.
02-20-2014 07:05 AM
Symptom:
Conditions:
Workaround:
02-20-2014 07:09 AM
Thanks Scott for your reply I will give a try and update you.
03-12-2014 06:40 AM
2.0.0 firmware is also available for this model.
