IPICS Problem - Cannot add RMS
engineerangelo
Level 3
Level 3
We are setting up an IPICS lab from scratch. I have already installed the IPICS software v4 to our CPS-MSP server. Now, I'm trying to add our RMS to IPICS. It says the version of RMS is not supported. The RMS I'm trying to add is a 2811 router with IP Voice IOS. I've already configured it with SSH v2, and AAA. And I can successfully access it via SSH v2 from my laptop via the PuTTY software. I have done the exact same thing that the IPICS Administration Guide has said. Please help. Thanks.
John Gillich
Level 4
Level 4
Make sure you are using IOS Version c2800nm-adventerprisek9-mz.151-4.M.bin. Here is an example config.
hostname Reno-RMS2811-1
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.151-4.M.bin
boot-end-marker
card type t1 0 1
logging message-counter syslog
logging buffered 51200 warnings
enable password cisco123
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone pctime -8
clock summer-time pst recurring
network-clock-participate wic 1
dot11 syslog
dot11 ssid ipics
vlan 12
authentication open
guest-mode
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.12.1
ip dhcp pool Local-Dot11-ipics-vlan12
   network 192.168.12.0 255.255.255.0
   option 150 ip 192.168.2.5
   default-router 192.168.12.1
   dns-server 192.168.2.6 24.205.192.61 66.215.64.14
   domain-name reno3260.com
no ip domain lookup
ip domain name cisco.com
ip multicast-routing
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
h323
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class permanent 1
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
voice-card 0
dspfarm
dsp services dspfarm
username ipics privilege 15 password 0 cisco123
username cisco password 0 cisco123
archive
log config
  hidekeys
controller T1 0/1/0
clock source internal
cablelength short 110
ds0-group 0 timeslots 24 type e&m-lmr
ds0-group 1 timeslots 1 type e&m-lmr
ds0-group 2 timeslots 2 type e&m-lmr
ds0-group 3 timeslots 3 type e&m-lmr
ds0-group 4 timeslots 4 type e&m-lmr
ds0-group 5 timeslots 5 type e&m-lmr
ds0-group 6 timeslots 6 type e&m-lmr
ds0-group 7 timeslots 7 type e&m-lmr
ds0-group 8 timeslots 8 type e&m-lmr
ds0-group 9 timeslots 9 type e&m-lmr
ds0-group 10 timeslots 10 type e&m-lmr
ds0-group 11 timeslots 11 type e&m-lmr
ds0-group 12 timeslots 12 type e&m-lmr
ds0-group 13 timeslots 13 type e&m-lmr
ds0-group 14 timeslots 14 type e&m-lmr
ds0-group 15 timeslots 15 type e&m-lmr
ds0-group 16 timeslots 16 type e&m-lmr
ds0-group 17 timeslots 17 type e&m-lmr
ds0-group 18 timeslots 18 type e&m-lmr
ds0-group 19 timeslots 19 type e&m-lmr
ds0-group 20 timeslots 20 type e&m-lmr
ds0-group 21 timeslots 21 type e&m-lmr
ds0-group 22 timeslots 22 type e&m-lmr
ds0-group 23 timeslots 23 type e&m-lmr
controller T1 0/1/1
ip tcp queuemax 100000
ip ftp username cisco
ip ftp password cisco123
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface Loopback0
ip address 192.168.10.1 255.255.255.255
interface FastEthernet0/0
ip address 192.168.2.10 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Dot11Radio0/3/0
no ip address
ip pim sparse-dense-mode
encryption vlan 12 key 1 size 40bit 0 7757895722 transmit-key
encryption vlan 12 mode wep mandatory
ssid ipics
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role root
interface Dot11Radio0/3/0.12
encapsulation dot1Q 12
ip address 192.168.12.1 255.255.255.0
interface Dot11Radio0/3/1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Vif1
ip address 192.168.11.1 255.255.255.252
ip pim sparse-mode
router ospf 192
log-adjacency-changes
network 192.168.2.0 0.0.0.255 area 1
network 192.168.10.0 0.0.0.255 area 1
network 192.168.11.0 0.0.0.255 area 1
network 192.168.12.0 0.0.0.255 area 1
ip default-gateway 192.168.2.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip pim rp-address 192.168.20.1
ip rtcp report interval 5001
control-plane
voice-port 0/0/0
voice-class permanent 1
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr m-lead audio-gate-in
lmr e-lead voice
lmr led-on
input gain auto-control
output attenuation auto-control
no echo-cancel enable
no comfort-noise
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-in 0
timing hangover 40
timing delay-voice tdm 160
connection trunk 10001
description VHF Radio
threshold noise -50
voice-port 0/0/1
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr led-on
input gain -10
no comfort-noise
timing hangover 500
connection trunk 10002
description CPI TTP-Multifunction
threshold noise -50
voice-port 0/2/0
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
connection trunk 20001
description VP 0/2/0 UHF radio
threshold noise -50
voice-port 0/2/1
operation 4-wire
type 3
bootup e-lead off
mgcp fax t38 ecm
dial-peer voice 555 voip
rtp payload-type lmr-tone 107
rtp payload-type nte-tone 108
voice-class codec 1
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
no vad
dial-peer voice 10001 voip
description VP 0/0/0 VHF
destination-pattern 10001
session protocol multicast
session target ipv4:239.192.10.1:21000
playout-delay nominal 0
playout-delay mode fixed
codec g711ulaw
no vad
dial-peer voice 20001 voip
destination-pattern 20001
session target ipv4:239.192.10.3:21000
codec g711ulaw
vad aggressive
dial-peer voice 10002 voip
description VP 0/0/1 CPI-TTP
destination-pattern 10002
session target ipv4:239.192.10.2:21000
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
dial-peer voice 556 voip
destination-pattern .T
voice-class codec 1
session target ipv4:192.168.2.5
session transport tcp
dtmf-relay rtp-nte
no vad
sip-ua
g729-annexb override
alias exec srb show run | begin
line con 0
exec-timeout 30 30
privilege level 15
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 22 0
privilege level 15
password cisco123
transport input telnet ssh
line vty 5 15
exec-timeout 0 0
privilege level 15
scheduler allocate 20000 1000
ntp server 128.250.36.3
ntp server 207.171.7.152
webvpn context Default_context
ssl authenticate verify all
no inservice
end
15 Replies 15
John Gillich
Level 4
Level 4
boot-start-marker
boot-end-marker
card type t1 0 1
aaa new-model
dot11 syslog
dot11 ssid ipics
vlan 12
authentication open
guest-mode
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice service voip
fax protocol cisco
h323
sip
  registrar server
voice class codec 1
voice-card 0
dspfarm
archive
log config
  hidekeys
controller T1 0/1/0
controller T1 0/1/1
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip pim sparse-mode
duplex auto
speed auto
no mop enabled
no ip address
shutdown
duplex auto
speed auto
no ip address
ssid ipics
station-role root
no ip address
shutdown
station-role root
interface Vif1
ip pim sparse-mode
router ospf 192
ip http server
control-plane
voice-port 0/0/0
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr led-on
no comfort-noise
timing hangover 40
threshold noise -50
voice-port 0/0/1
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr led-on
input gain -10
no comfort-noise
timing hangover 500
threshold noise -50
voice-port 0/2/0
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
threshold noise -50
voice-port 0/2/1
operation 4-wire
type 3
bootup e-lead off
mgcp fax t38 ecm
voice-class codec 1
dtmf-relay rtp-nte
no vad
codec g711ulaw
no vad
codec g711ulaw
vad aggressive
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
line con 0
exec-timeout 30 30
privilege level 15
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 22 0
privilege level 15
password cisco123
line vty 5 15
exec-timeout 0 0
privilege level 15
no inservice
end
I finally got it added. I upgraded it to advanced enterprise and I added an E1 card. But we only have a VWIC 2MFT-G703 card. Will this work? Thanks in advance.
Hi engineerangelo,
Could you please tell me about above shared configuration sample. is it worked in your scnerio. so that i can assume this configuration as working sample which will lead me to add RMS with IPICS. please respond.
thanks in advance !
Rizwan Haider Siddiqui
Hi Rizwan,
Here's my configuration:
sho run
Building configuration...
Current configuration : 21667 bytes
version 12.4
hostname LMRRMS
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-24.T5.bin
boot-end-marker
aaa new-model
--More--                           aaa session-id common
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip domain name comnet
no ipv6 cef
voice service voip
--More--                            allow-connections sip to sip
fax protocol cisco
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
voice class codec 1
signal pattern idle transmit 0000
--More--                           !
voice-card 0
dspfarm
username cisco privilege 15 password 0 cisco
archive
log config
hidekeys
--More--                           !
controller E1 0/2/0
ds0-group 0 timeslots 31 type e&m-lmr
ds0-group 16 timeslots 30 type e&m-lmr
--More--                            ds0-group 19 timeslots 19 type e&m-lmr
controller E1 0/2/1
--More--                            ds0-group 18 timeslots 18 type e&m-lmr
ip ssh version 2
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vif1
ip address 192.168.20.1 255.255.255.252
--More--                            ip pim sparse-dense-mode
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
auto-cut-through
operation 4-wire
type 3
--More--                            signal lmr
lmr e-lead voice
lmr led-on
input gain -10
no comfort-noise
timing hangover 500
connection trunk 1001
threshold noise -50
voice-port 0/0/1
operation 4-wire
type 3
voice-port 0/2/0:0
auto-cut-through
lmr e-lead voice
--More--                            playout-delay maximum 250
playout-delay nominal 100
playout-delay minimum high
no comfort-noise
timeouts teardown lmr infinity
timing hangover 40
shutdown
description #0/2/0:0#1307955330675# IDLE 237
voice-port 0/2/0:1
auto-cut-through
lmr e-lead voice
no comfort-noise
--More--                            timing hangover 40
shutdown
description #0/2/0:1#1307955330783# IDLE 238
voice-port 0/2/0:2
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:2#1307956366588# IDLE 239
voice-port 0/2/0:3
auto-cut-through
--More--                            lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:3#1307956366637# IDLE 240
voice-port 0/2/0:4
auto-cut-through
lmr e-lead voice
no comfort-noise
--More--                            timeouts teardown lmr infinity
timing hangover 40
shutdown
description #0/2/0:4#1307956858225# IDLE 241
voice-port 0/2/0:5
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:5#1307956858276# IDLE 242
voice-port 0/2/0:6
--More--                            voice-class permanent 1
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:6#1307957806037# IDLE 243
voice-port 0/2/0:7
auto-cut-through
lmr e-lead voice
--More--                            playout-delay nominal 100
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:7#1307957806158# IDLE 244
voice-port 0/2/0:8
auto-cut-through
lmr e-lead voice
no comfort-noise
shutdown
description #0/2/0:8#1308102797675# IDLE 245
voice-port 0/2/0:9
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:9#1308102797792# IDLE 246
voice-port 0/2/0:10
--More--                            auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:10#1308103139057# IDLE 247
voice-port 0/2/0:11
auto-cut-through
lmr e-lead voice
--More--                            playout-delay minimum high
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:11#1308103139181# IDLE 248
voice-port 0/2/0:12
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
--More--                            shutdown
description #0/2/0:12#1308103411464# IDLE 249
voice-port 0/2/0:13
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:13#1308103426401# IDLE 250
voice-port 0/2/0:14
auto-cut-through
--More--                            lmr m-lead audio-gate-in
lmr e-lead voice
no comfort-noise
timing hangover 40
connection trunk 199909290914
description #0/2/0:14#1308103720378# INUSE 251
voice-port 0/2/0:15
auto-cut-through
lmr e-lead voice
--More--                            no comfort-noise
timing hangover 40
connection trunk 199909290915
description #0/2/0:15#1308103720403# INUSE 252
voice-port 0/2/0:16
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:16#1307953484702# IDLE 253
--More--                           !
voice-port 0/2/0:17
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:17#1307953484752# IDLE 254
voice-port 0/2/0:18
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:18#1307953543864# IDLE 255
voice-port 0/2/0:19
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
--More--                            shutdown
description #0/2/0:19#1307953543902# IDLE 256
voice-port 0/2/0:20
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/0:20#1307954393376# IDLE 257
voice-port 0/1/0
auto-cut-through
operation 4-wire
type 3
--More--                            signal lmr
lmr e-lead voice
lmr led-on
input gain -10
no comfort-noise
timing hangover 500
connection trunk 1002
threshold noise -50
voice-port 0/1/1
operation 4-wire
type 3
voice-port 0/2/1:0
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:0#1307955330675# IDLE 237
voice-port 0/2/1:1
auto-cut-through
lmr e-lead voice
no comfort-noise
shutdown
description #0/2/1:1#1307955330783# IDLE 238
voice-port 0/2/1:2
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:2#1307956366588# IDLE 239
voice-port 0/2/1:3
auto-cut-through
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:3#1307956366637# IDLE 240
voice-port 0/2/1:4
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:4#1307956858225# IDLE 241
voice-port 0/2/1:5
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:5#1307956858276# IDLE 242
voice-port 0/2/1:6
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:6#1307957806037# IDLE 243
voice-port 0/2/1:7
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:7#1307957806158# IDLE 244
voice-port 0/2/1:8
auto-cut-through
lmr e-lead voice
no comfort-noise
shutdown
description #0/2/1:8#1308102797675# IDLE 245
voice-port 0/2/1:9
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:9#1308102797792# IDLE 246
voice-port 0/2/1:10
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:10#1308103139057# IDLE 247
voice-port 0/2/1:11
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:11#1308103139181# IDLE 248
voice-port 0/2/1:12
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
--More--                            shutdown
description #0/2/1:12#1308103411464# IDLE 249
voice-port 0/2/1:13
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:13#1308103426401# IDLE 250
voice-port 0/2/1:14
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
connection trunk 199909291914
description #0/2/1:14#1308103720378# INUSE 251
voice-port 0/2/1:15
auto-cut-through
lmr e-lead voice
timing hangover 40
connection trunk 199909291915
description #0/2/1:15#1308103720403# INUSE 252
voice-port 0/2/1:16
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:16#1307953484702# IDLE 253
--More--                           !
voice-port 0/2/1:17
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:17#1307953484752# IDLE 254
voice-port 0/2/1:18
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:18#1307953543864# IDLE 255
voice-port 0/2/1:19
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
--More--                            shutdown
description #0/2/1:19#1307953543902# IDLE 256
voice-port 0/2/1:20
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 40
shutdown
description #0/2/1:20#1307954393376# IDLE 257
mgcp fax t38 ecm
--More--                           !
dial-peer voice 1002 voip
destination-pattern 1002
session target ipv4:239.192.100.3:21000
no vad
dial-peer voice 1001 voip
destination-pattern 1001
session target ipv4:239.192.100.2:21000
no vad
dial-peer voice 909290914 voip
destination-pattern 199909290914
session target ipv4:239.192.50.1:21000
codec g711ulaw
no vad
dial-peer voice 909291914 voip
--More--                            description #0/2/1:14#1308103720378# INUSE 251
destination-pattern 199909291914
codec g711ulaw
no vad
dial-peer voice 909290915 voip
destination-pattern 199909290915
codec g711ulaw
no vad
dial-peer voice 909291915 voip
destination-pattern 199909291915
--More--                            codec g711ulaw
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
gateway
media-inactivity-criteria rtcp
timer receive-rtcp 5
timer receive-rtp 1200
sip-ua
--More--                           line con 0
line aux 0
line vty 0 4
exec-timeout 22 0
privilege level 15
transport input ssh
end
LMRRMS#
LMRRMS#
You are missing.
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 0 0
privilege level 15
password cisco123
line vty 5 15
exec-timeout 0 0
privilege level 15
Hi engineerangelo & John Gillich,
Thank you both of you for sharing with me the configuration and the missing stuff. So i can make above configuration as my Sample Config for RMS which is functional ? Secondly I need LMR configuration sample too.
Moreover, if above configuration is for RMS and LMR both then please draw the line which is for RMS and which is for RMS/LMR.
Bundle of thanks Man ! 🙂
The voice ports that are E&M ports and the associated dial-peesr are the LMR portion and added statically.
So below the voice-port 0/0/0 and dial-peer 1001 are the LMR port/channel and you would add the channel on the server configuration/channel using the Ncast address in the dial-peer.
LMR channel
voice-port 0/0/0
auto-cut-through
operation 4-wire
type 3
signal lmr
lmr e-lead voice
lmr led-on
input gain -10
no  comfort-noise
timing hangover 500
threshold noise -50
no  vad
RMS Channel.
The DSO's and associated dial-peer are part of the RMS and configured by   IPICS after you add them under the loopback tab.   configuration/rms/loopback.
voice-port 0/2/0:14
auto-cut-through
lmr  e-lead voice
no  comfort-noise
timing hangover 40
codec g711ulaw
no vad
voice-port 0/2/1:14
auto-cut-through
lmr  e-lead voice
no  comfort-noise
timing hangover 40
codec g711ulaw
no vad
Hope this helps,
John
Hello John,
Thank you for your provided effective info.
I am using Cisco IP phone as PTT device. could you please tell me can i use one ip phone with one channel and second ip phone with other channel having no RMS involved. can i test PTT of different channel involving VTG of IPICS without RMS/LMR ?
Rizwan Haider
Rizwan,
You can use the IP phone to connect to channels that you have created on the IPICS server as long as the phone is on the same multicast network. The RMS is requiered for a VTG to combine the channels.
If you have channel A and B assigned to the user that you log into with the IP phone and channel B also assigned to that user you can log in on two phones with channel A selected on one phone and channel B on the other phone. You cannot combine the channels into a VTG without the RMS.
John
A router media service (RMS) provides a variety of functions for Cisco IPICS, including the following:
A router with DSP resources used to:
Support through its loopback functionality for combining two or more VTGs
Mixing of multicast channels to support VTGs
     Mixing of remote PMC unicast connections to a multicast channel or a VTG
Support for unicast M1:U12:M2 connection trunks
RMS is managed from the IPICS server.
Hello Mr. John,
I got your points and thank you for your support.
I have one more question below
I have created user-1 with PIN and password to login into IP phone and mapped with Channel-1
same, created another user-2 and login into IP Phone and mapped to Channel-2
Then I created VTG-1 and added Channel-1 and Channel-2.
Now, one IP-Phone7961 as PTT device logged in with user-1
Second, IP-Phone7960 as PTT device logged in with user-2
I have three option to select;
1. Channel-1
2. Channel-2
3. VTG-1
If both IP Phone select Channel-1 then they can PTT with each other.
If both IP Phone selecct VTG-1 then they can also PTT with each other.
but If one IP Phone select Channel-1 then other select Channel-2 then they are unable to PTT with each other.
Furthermore, If I logged IP phone with Channel-1 and other IDC logged in with one Channel-2 and select RMS site then PTT successfully done with same channel and VTG but one end user with one channel and other end user with other channel then they are unable to PTT.
Please suggest !!!
Thanks in Advance !!!
Rizwan Haider Siddiqui........
Rizwan,
I have your scenario setup in my lab the only difference is I am using a 7970 and 7961 IP phone. It works ok for me. Please check your Firmware version on your phones.
http://www.cisco.com/en/US/docs/interoperability_systems/c_ipics/compatibility/ciscomp.htm
You may need to debug the the packets using a sniffer.
Here are som LMR debug commands for the RMS. The two ip phones are connecting directly to the RMS the server is not involved.
LMR-Debugging
  • •1.     “debug vpm trunk”
    • •a.      (to debug trunk information.)
  • •2.     “debug vpm signal”
    • •a.      (used to check if DSP detect LMR packets)
  • •3.     "debug voip hpi command"
    • •a.      (is able to show the actual rtp payload type download to dsp in "voice_encap_config" command. )
  • •4.     “show voice lmr
    • •a.      (used to get the ip address and port number)
  • •5.     “debug voip rtp packet remote-ip ipaddress remote-port portnumber”
    • •a.      (to show actual rtp traffic for the ip address and port number from the “show voice lmr ” command.)
  • •6.     show voice trace
    • •a.      (To display the call trace information about a specified port)
  • •7.     6. To reset voice port;
    • •1)   shut/no shut
    • •2)   test lmr clear
Hello John,
Thank you for your continues help. I have attached RMS "Show running-configuration" please have a technical look and help me.
Cisco-IP Phone 7960 = login with user rizwan which is member of channel-rizwan
Cisco-IP Phone 7961 = login with user Naresh which is member of channel-naresh
both channels are member of Hybrid-VTG (VTG-Name)
IDC on Laptop = login with user IDC which is member of Hybrid-VTG
Result: IDC shows both channel and PTT to each channel seperately and vice versa but ip-phone (rizwan-channel) and 2nd ip phone (naresh-channel) are unable to PTT each other. please check
Thank you........
------------------ show running-config ------------------
Current configuration : 37364 bytes
version 15.0
service password-encryption
hostname RMS-Site
boot-start-marker
boot-end-marker
card type e1 0 1
card type e1 0 2
card type e1 0 3
enable password 7
aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
ip domain name abc.com
no ipv6 cef
voice service voip
sip
  registrar server
voice class codec 1
voice-card 0
dspfarm
voice-card 1
dspfarm
crypto pki trustpoint TP-self-signed-295064176
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-295064176
revocation-check none
rsakeypair TP-self-signed-295064176
crypto pki certificate chain TP-self-signed-295064176
certificate self-signed 01
  3082024A 308201B3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393530 36343137 36301E17 0D313130 37313231 33313932
  365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3239 35303634
  31373630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  D548C33F 9FA0C0C3 7E1B4CC5 F7F3354C 8704A54D 3851E36F ED80129F DB17BAC1
  DEA97A16 F29B0A57 3CB98CCE FA9C1BB8 93EC9C93 1713AD87 3C077C86 DA785EF6
  0BF2837A B2CBDC03 70452EC9 D0198AF9 79A3E89A 1D44C42E D742EFBF E641A277
  830A4759 F5C2353D EAEB860E BEA00155 71F201DF D1FFD7B1 66A28ED2 8D0CA47D
  02030100 01A37430 72300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  11041830 16821447 61727269 736F6E2E 444C492E 7061662E 636F6D30 1F060355
  1D230418 30168014 0F811602 FC721C3F D314110B 5AE21129 F8868586 301D0603
  551D0E04 1604140F 811602FC 721C3FD3 14110B5A E21129F8 86858630 0D06092A
  864886F7 0D010104 05000381 8100B1CD A1870570 BD4FDF58 2A4EC18A F0A58B07
  23655DE1 0429EE79 6F6B9AA8 58BC993B 02122101 B12B94F7 F2A4807D 0D7459A9
  3FD05A18 E6CD3389 F68A72AF 2649C2DC 7847B9F6 561BBF85 897ADA7C CA31EB58
  528DFC63 F6BF83E7 25456185 93CD7F40 4AB761E0 8D927AEB 9C5814C4 94245A96
  50142B3E 56AAF001 A0B89774 7732
            quit
license udi pid CISCO2821 sn (Manually Removed)
username admin privilege 15 password 7
username ipics privilege 15 password 7
redundancy
controller E1 0/1/0
ds0-group 24 timeslots 24 type e&m-lmr
ds0-group 25 timeslots 25 type e&m-lmr
ds0-group 26 timeslots 26 type e&m-lmr
ds0-group 27 timeslots 27 type e&m-lmr
ds0-group 28 timeslots 28 type e&m-lmr
ds0-group 29 timeslots 29 type e&m-lmr
controller E1 0/1/1
controller E1 0/2/0
controller E1 0/2/1
controller E1 0/3/0
controller E1 0/3/1
ip ssh version 2
interface Loopback0
ip address 172.40.249.1 255.255.255.255
ip pim sparse-mode
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.40.250.34 255.255.255.252
ip pim sparse-mode
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface Vif1
ip address 172.40.249.10 255.255.255.252
ip pim sparse-mode
router ospf 1
network 172.32.20.0 0.0.0.255 area 1
network 172.40.249.1 0.0.0.0 area 1
network 172.40.250.32 0.0.0.3 area 1
no ip http server
control-plane
voice-port 0/1/0:0
voice-port 0/1/0:1
voice-port 0/1/0:2
voice-port 0/1/0:3
voice-port 0/1/0:4
voice-port 0/1/0:5
voice-port 0/1/0:6
voice-port 0/1/0:7
voice-port 0/1/0:8
voice-port 0/1/0:9
voice-port 0/1/0:10
voice-port 0/1/0:11
voice-port 0/1/0:12
voice-port 0/1/0:13
voice-port 0/1/0:14
voice-port 0/1/0:15
voice-port 0/1/0:16
voice-port 0/1/0:17
voice-port 0/1/0:18
voice-port 0/1/0:19
voice-port 0/1/0:20
voice-port 0/1/0:21
voice-port 0/1/0:22
voice-port 0/1/0:23
voice-port 0/1/0:24
voice-port 0/1/0:25
voice-port 0/1/0:26
voice-port 0/1/0:27
voice-port 0/1/0:28
voice-port 0/1/0:29
voice-port 0/2/0:0
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:0#1311076353130# IDLE 529
voice-port 0/2/0:1
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:1#1311076353223# IDLE 530
voice-port 0/2/0:2
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:2#1310989445018# IDLE 531
voice-port 0/2/0:3
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:3#1310989445063# IDLE 532
voice-port 0/2/0:4
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:4#1310990046293# IDLE 533
voice-port 0/2/0:5
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:5#1310990169126# IDLE 534
voice-port 0/2/0:6
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:6#1310990396122# IDLE 535
voice-port 0/2/0:7
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:7#1310990697581# IDLE 536
voice-port 0/2/0:8
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:8#1310990831284# IDLE 537
voice-port 0/2/0:9
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:9#1310990857616# IDLE 538
voice-port 0/2/0:10
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:10#1310990968850# IDLE 539
voice-port 0/2/0:11
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:11#1310990981083# IDLE 540
voice-port 0/2/0:12
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:12#1310990992401# IDLE 541
voice-port 0/2/0:13
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:13#1310991099454# IDLE 542
voice-port 0/2/0:14
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:14#1310991274408# IDLE 543
voice-port 0/2/0:15
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:15#1310991602991# IDLE 544
voice-port 0/2/0:16
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:16#1310991732046# IDLE 545
voice-port 0/2/0:17
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:17#1310993141232# IDLE 546
voice-port 0/2/0:18
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:18#1310993304462# IDLE 547
voice-port 0/2/0:19
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:19#1310993304574# IDLE 548
voice-port 0/2/0:20
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:20#1310993358903# IDLE 549
voice-port 0/2/0:21
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:21#1310993359025# IDLE 550
voice-port 0/2/0:22
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:22#1310993410498# IDLE 551
voice-port 0/2/0:23
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:23#1310993410590# IDLE 552
voice-port 0/2/0:24
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:24#1310993476255# IDLE 553
voice-port 0/2/0:25
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:25#1310993476394# IDLE 554
voice-port 0/2/0:26
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:26#1310993484468# IDLE 555
voice-port 0/2/0:27
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/0:27#1310993484556# IDLE 556
voice-port 0/2/0:28
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
connection trunk 199909290928
description #0/2/0:28#1310993494276# INUSE 557
voice-port 0/2/0:29
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
connection trunk 199909290929
description #0/2/0:29#1310993494293# INUSE 558
voice-port 0/1/1:0
voice-port 0/1/1:1
voice-port 0/1/1:2
voice-port 0/1/1:3
voice-port 0/1/1:4
voice-port 0/1/1:5
voice-port 0/1/1:6
voice-port 0/1/1:7
voice-port 0/1/1:8
voice-port 0/1/1:9
voice-port 0/1/1:10
voice-port 0/1/1:11
voice-port 0/1/1:12
voice-port 0/1/1:13
voice-port 0/1/1:14
voice-port 0/1/1:15
voice-port 0/1/1:16
voice-port 0/1/1:17
voice-port 0/1/1:18
voice-port 0/1/1:19
voice-port 0/1/1:20
voice-port 0/1/1:21
voice-port 0/1/1:22
voice-port 0/1/1:23
voice-port 0/1/1:24
voice-port 0/1/1:25
voice-port 0/1/1:26
voice-port 0/1/1:27
voice-port 0/1/1:28
voice-port 0/1/1:29
voice-port 0/2/1:0
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:0#1311076353130# IDLE 529
voice-port 0/2/1:1
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:1#1311076353223# IDLE 530
voice-port 0/2/1:2
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:2#1310989445018# IDLE 531
voice-port 0/2/1:3
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:3#1310989445063# IDLE 532
voice-port 0/2/1:4
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:4#1310990046293# IDLE 533
voice-port 0/2/1:5
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:5#1310990169126# IDLE 534
voice-port 0/2/1:6
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:6#1310990396122# IDLE 535
voice-port 0/2/1:7
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:7#1310990697581# IDLE 536
voice-port 0/2/1:8
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:8#1310990831284# IDLE 537
voice-port 0/2/1:9
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:9#1310990857616# IDLE 538
voice-port 0/2/1:10
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:10#1310990968850# IDLE 539
voice-port 0/2/1:11
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:11#1310990981083# IDLE 540
voice-port 0/2/1:12
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:12#1310990992401# IDLE 541
voice-port 0/2/1:13
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:13#1310991099454# IDLE 542
voice-port 0/2/1:14
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:14#1310991274408# IDLE 543
voice-port 0/2/1:15
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:15#1310991602991# IDLE 544
voice-port 0/2/1:16
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:16#1310991732046# IDLE 545
voice-port 0/2/1:17
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:17#1310993141232# IDLE 546
voice-port 0/2/1:18
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:18#1310993304462# IDLE 547
voice-port 0/2/1:19
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:19#1310993304574# IDLE 548
voice-port 0/2/1:20
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:20#1310993358903# IDLE 549
voice-port 0/2/1:21
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:21#1310993359025# IDLE 550
voice-port 0/2/1:22
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:22#1310993410498# IDLE 551
voice-port 0/2/1:23
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:23#1310993410590# IDLE 552
voice-port 0/2/1:24
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:24#1310993476255# IDLE 553
voice-port 0/2/1:25
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:25#1310993476394# IDLE 554
voice-port 0/2/1:26
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:26#1310993484468# IDLE 555
voice-port 0/2/1:27
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
shutdown
description #0/2/1:27#1310993484556# IDLE 556
voice-port 0/2/1:28
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
connection trunk 199909291928
description #0/2/1:28#1310993494276# INUSE 557
voice-port 0/2/1:29
auto-cut-through
lmr e-lead voice
no comfort-noise
timing hangover 80
connection trunk 199909291929
description #0/2/1:29#1310993494293# INUSE 558
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
voice-class codec 1
dtmf-relay rtp-nte
no vad
description sip provider
session target ipv4:172.32.20.10
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 909290928 voip
destination-pattern 199909290928
session target ipv4:239.193.32.10:21018
codec g711ulaw
no vad
dial-peer voice 909291928 voip
destination-pattern 199909291928
session target ipv4:239.192.172.2:21000
codec g711ulaw
no vad
dial-peer voice 909290929 voip
destination-pattern 199909290929
codec g711ulaw
no vad
dial-peer voice 909291929 voip
destination-pattern 199909291929
session target ipv4:239.192.172.1:21000
codec g711ulaw
no vad
gateway
sip-ua
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
line aux 0
line vty 0 4
exec-timeout 22 0
privilege level 15
line vty 5 15
exec-timeout 22 0
privilege level 15
transport input ssh
ntp server 172.32.20.232
end
[email protected]
Hi Rizwan,
Are both channels and users in the same location? Would you like to contact me and we can set up a meeting to have a look at your config?
John
please share with me your contact (private/public) ....... Thank You
