Problem when i add an IP camera
csco10971283
when I add an IP camera 2500 on vsom 6.3.1 , i can't , the problem is (-1 [ERROR] could not start proxy p_s1_youyou_1) , please can you help me .
Ahmed Ossama
CCIE#26611
Try this:
Go the VSMC page of the media server that the camera is configured on:
http:///vsmc
Configuration > Media Server > Local Repositories
  1. Uncheck all the repositories checkboxes that are checked.
  2. Click the Update Button at the bottom.
  3. Make sure you see the "Successfully Updated" message
  4. Check the same repository checkboxes again
  5. Click the Update Button at the bottom.
  6. Make sure you see the "Successfully Updated" message
  7. Restart the Cisco Services again from Restart Server --> Restart Media Server button
Let me know if this restores operation for your newly added proxy, and if it does not, please include the snippet from the ims.log containing this error message, along with the 15 messages before it and the 15 after it so I can get a better understanding of the problem.
Sean
5 Replies 5
Sean Merrow
Level 10
Level 10
If the camera is running 1.x firmware, this is likely your problem, and the upgrade process will require you to use the Upgrade Utility.  If you are running 2.x firmware, then this may not be your problem, but you can upgrade the camera either via the camera's GUI or via the VSMC page of the media server.  Please review the Upgrade Instructions for the 2500 and pay particular attention to what version you are upgrading from.
Follow up and let us know if an upgrade helps.
Thank you,
Sean
Hi Sean,
  Thank you for your respond , the firmware on 2500 is (2.1.7) latest version , but I do not know why this problem appears , please advise .
BR
Ahmed Ossama
CCIE#26611
Try this:
http:///vsmc
Sean
Hi ,
  it's working now , thank you .
BR
Ahmed Ossama
CCIE#26611
Hi Sean,
  When I switch on the server and open Cisco Video Surveillance it gives me an error "Could not connect to host localhost".
When I start the services using a command "etc/init.d/cisco start" it works. How can we eliminate the error. I dont want to enter the command manually each time.
BR
Ahmed Ossama
CCIE#26611
