Vivotek Cameras in VSOM
jwood.ok
I'm pretty sure I know the answer to this, just wanted to make sure.  From what I can tell, adding Vivotek Cameras appears to require 7.9.0.  I am at 7.8.0, so I wanted to be sure there wasn't a driverpack that could be added to allow adding them without the full upgrade first.
voyo
For VSM 7.8 there is available driver pack only for Vivotek 8801 and 8401 encoders.
But depending on your luck (and camera model) you can try to add it to VSM as 'generic Onvif' device.
And here you can find release notes for 7.9 Vivotek drivers -
https://www.cisco.com/c/en/us/td/docs/security/physical_security/video_surveillance/network/vsm/driver_pack/release_notes/Vivotek__1-0-01d/driverpack_rn_vivotek_1-0-01d.html
Starting from VSM 7.10 Cisco officially supports Vivotek SD9361-EHL and SD9362-EH/ SD9362-EHL models.
I hope it helps.
voyo
I hope it helps.
Your information was certainly helpful.  The cameras we have are the SD9362-EHL, so it looks like we will definitely need to upgrade off of 7.8.  Thank you!
