AdditionalLocalIPs on Linux
AlanT
The DAG FAQ has a section on adding these for DAGs running on windows, where you add an additional section to C:\inetpub\wwwroot\dag\www\web.config. Is there an equivalent for Linux? Is it necessary? It seems like it might be, I’m having some difficulty getting to the admin panel for a Linux DAG I have that I’m more remote than usual too. Any insight welcome!
jamieis
Hey there @AlanT,
AdditionalLocalIPs is not required for the Linux Duo Access Gateway because the admin console is accessible on port 8443. You can use network level controls to decide who can access port 8443.
AdditionalLocalIPs is only used on the Windows Duo Access Gateway because by default it only allows the local Windows server to access the admin console.
Thanks for being a Duo customer!
Jamie
