CAS and Duo -- Trigger MFA by Integrated Application?
Joshua_Brodie
For leveraging Duo with CAS, is it possible to enable MFA based on the application (so not all applications on MFA immediately)?
DuoKristina
According to Apereo, yes.
MFA can be triggered for a specific application registered inside the CAS service registry.
https://apereo.github.io/cas/5.0.x/installation/Configuring-Multifactor-Authentication.html
Duo, not DUO.
DuoKristina
Duo, not DUO.
