CentOS 7.x and SSH integration - error "No Supported Authentication Methods"
terry.cutler
I’m new to Duo and looking to understand it.
I’ve followed the instructions at Duo Unix - 2FA for SSH with PAM Support (pam_duo) | Duo Security
I’ve successfully integrated with Ubuntu for both a local privileged access and via SSH.
However, when attempting similar with CentOS 7.x, I keep running into an issue. The local console privileged access works as expected with the Duo options. When I attempt to connect via SSH using PuTTY with Windows, I get the error “Disconnected: No supported authentication methods available (server sent: publickey)”
Any suggestions?
stacybrock
How do you have the auth directives in /etc/pam.d/password-auth-ac configured?
Hello Stacybrock, what setting are need for password-aut-ac? I just had this issue after reboot my centos 7
Ahmad_Barhoush
Did you guys manage to solve this ?
I’m facing the same problem, it was working fine with Duo but after i rebooted the machine this error showed up !
