Cisco SSL VPN + AD RADIUS authentication
Exonix1
currently we are using MS RRAS VPN but we are going replace it to Cisco ASA 5510-X with Cisco AnyConnect. I would like to know whether I have right understood the authentication process. I have the following schema:
  1. VPN client connects to Cisco VPN
  2. Cisco VPN asks DUO Proxy for the authentication
  3. Duo Proxy asks MS RADIUS for the authentication
  4. RADIUS says to Dup Proxy “OK”
  5. DUO Proxy asks DUO server for the authentication and User approves it by DUO Mobile
  6. DOU Proxy answers Cisco VPN “OK” and Cisco VPN establishes VPN connection.
Is everything right?
DuoKristina
Take a look at the networking diagram and accompanying description at the bottom of this page:
Your upstream RADIUS server (NPS or whatever) would be #3. Alternatively, you could point the Duo proxy straight at AD, so your domain controller would be #3.
Duo, not DUO.
Hello Kristina,
this is my configuration file of DUO Proxy:
[radius_client]
host=10.255.9.16
secret=******
[radius_server_auto]
ikey=XXXXXXXXXXXXXXXXXXX
skey=YYYYYYYYYYYYYYYYYYYYYYYYYYYYY
radius_ip_1=10.254.1.200
radius_secret_1=******
failmode=safe
client=radius_client
pass_through_all=true
allow_concat=true
port=1812
[main]
debug=true
then I try to check VPN in Cisco, I get an error:
test aaa-server authentication Duo host 10.254.1.114 username vpn_asa password 1q2wazsxDCFV
2018-01-02T11:31:29+0100 [-] Duo Security Authentication Proxy 2.7.0 - Init Complete
2018-01-02T11:31:29+0100 [-] RadiusClient starting on 56935
2018-01-02T11:31:29+0100 [-] Starting protocol <duoauthproxy.lib.radius.client.RadiusClient instance at 0x02A5CC88>
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] Packet dump - received from 10.254.1.200:
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] '\x014\x00A\xff-\xa8\xbc\x95N\x85Q\xb5\xb2A\xe0\x81\x97i[\x01\tvpn_asa\x02\x12\xa77e\xfe\xf9\x113 \xdde\xf71tt\xcc\xde\x04\x06\n\xfe\x01\xc8\x
05\x06\x00\x00\x00\x17=\x06\x00\x00\x00\x05'
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] Sending request from 10.254.1.200 to radius_server_auto
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] Received new request id 52 from ('10.254.1.200', 20747)
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] (('10.254.1.200', 20747), 52): login attempt for username u'vpn_asa'
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] Sending request for user u'vpn_asa' to ('10.255.9.16', 1812) with id 212
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] Packet dump - sent to 10.255.9.16:
2018-01-02T11:31:40+0100 [DuoForwardServer (UDP)] '\x01\xd4\x00A\xa0;|\xd5\x83\x0fP\x8a-Y\xd7,\x0f$\xa5\x98\x01\tvpn_asa\x02\x12\xc3\xf4\xefM\x83\xc2OwT\xfbe\x8c\xfc\xb7\xad\x12\x04\x06\n\xfe\
x01r\x05\x06\x00\x00\x00\x17=\x06\x00\x00\x00\x05'
2018-01-02T11:31:40+0100 [RadiusClient (UDP)] Packet dump - received from 10.255.9.16:
2018-01-02T11:31:40+0100 [RadiusClient (UDP)] '\x02\xd4\x00fi\x9f\x1c3\xb3xI\xaa\xc6Z\x18O\xaf\xd7\xa2\xbf\x07\x06\x00\x00\x00\x01\x06\x06\x00\x00\x00\x02\x19.\x9e"\t\xc1\x00\x00\x017\x00\x01\
x02\x00\n\xff\t\x10\x00\x00\x00\x00\x1d*\x9f\xdfC\xc1`\x01\x01\xd3\t\xe9\x84\x96u\xad\x00\x00\x00\x00\x00\x00h\xcf\x1a\x0c\x00\x00\x017\x07\x06\x00\x00\x00\x02\x1a\x0c\x00\x00\x017\x08\x06\x00
\x00\x00\x04'
2018-01-02T11:31:40+0100 [RadiusClient (UDP)] Got response for id 212 from ('10.255.9.16', 1812); code 2
2018-01-02T11:31:40+0100 [RadiusClient (UDP)] http POST to https://XXX-XXXXXXX.duosecurity.com:443/rest/v1/preauth: user=vpn_asa
2018-01-02T11:31:40+0100 [duoauthproxy.lib.http._DuoHTTPClientFactory#info] Starting factory <_DuoHTTPClientFactory: https://XXX-XXXXXXX.duosecurity.com:443/rest/v1/preauth>
2018-01-02T11:31:41+0100 [HTTPPageGetter (TLSMemoryBIOProtocol),client] Duo preauth call failed
        Traceback (most recent call last):
          File "twisted\internet\defer.pyc", line 588, in _runCallbacks
          File "twisted\internet\defer.pyc", line 1184, in gotResult
          File "twisted\internet\defer.pyc", line 1126, in _inlineCallbacks
          File "twisted\python\failure.pyc", line 389, in throwExceptionIntoGenerator
        --- <exception caught here> ---
          File "duoauthproxy\lib\radius\duo_server.pyc", line 141, in preauth
          File "duoauthproxy\lib\duo_async.pyc", line 182, in preauth
          File "twisted\internet\defer.pyc", line 1128, in _inlineCallbacks
          File "duoauthproxy\lib\duo_async.pyc", line 145, in call
          File "duoauthproxy\lib\duo_async.pyc", line 159, in _parse_response
        duoauthproxy.lib.duo_async.DuoAPIFailClosedError: 40102: Invalid integration key in request credentials
2018-01-02T11:31:41+0100 [HTTPPageGetter (TLSMemoryBIOProtocol),client] (('10.254.1.200', 20747), 52): Denied Duo login on unexpected failure
2018-01-02T11:31:41+0100 [HTTPPageGetter (TLSMemoryBIOProtocol),client] (('10.254.1.200', 20747), 52): Returning response code 3: AccessReject
2018-01-02T11:31:41+0100 [HTTPPageGetter (TLSMemoryBIOProtocol),client] (('10.254.1.200', 20747), 52): Sending response
2018-01-02T11:31:41+0100 [HTTPPageGetter (TLSMemoryBIOProtocol),client] Packet dump - sent to 10.254.1.200:
2018-01-02T11:31:41+0100 [HTTPPageGetter (TLSMemoryBIOProtocol),client] '\x034\x00<:s\x97\xb9\xdd3\x1b\xe7C\x83\xfbkR\xef\x8c\xdd\x12(Denied Duo login on unexpected failure'
2018-01-02T11:31:41+0100 [duoauthproxy.lib.http._DuoHTTPClientFactory#info] Stopping factory <_DuoHTTPClientFactory: https://XXX-XXXXXXX.duosecurity.com:443/rest/v1/preauth>
How can i fix it?
it is very strange. We have also DUO proxy for RRAS.
I have taken ikey and skey from this App - it works!
But why the ikey and skey for Cisco don’t work?
Acount ID: 0199-1825-13
Did you create the right kind of Cisco application (you want “Cisco RADIUS VPN” instead of “Cisco SSL VPN”)? Perhaps the Cisco application information was copied/pasted incorrectly?
I suggest you contact Duo support about this issue - it’s pretty much impossible to troubleshoot this error without your actual integration information (ikey and host) but we don’t want you sharing that info to the whole community.
Duo, not DUO.
