Duo Authentication for Windows RDP - Display Resolution too Low
firemandan9
I’m setting up a new Windows Server 2019 RDP Duo Authentication and everything looks normal during an RDP login until the DUO prompt comes up with such a low display resolution that I can’t see most of the prompt.
Display resolution is fine before and after the prompt so long a I accept the auto push on my Duo Mobile. Any know way to fix this?
0 Replies 0
