01-10-2017 11:13 AM
Hello all,
Sorry if this is not the correct place for my question. I am new and trying to learn. Please let me know and I will move/delete this.
I am trying to set up duo-unix to do 2FA + ssh-key authentication on a linux VM (ubuntu 14.04) as a test. I am using the ubuntu repository supplied in the guide/doc here :: https://duo.com/docs/duounix
ubuntu@duo2fa-test-free:~ sudo apt-get install build-essential libss-dev
ubuntu@duo2fa-test-free:~ sudo apt-get update && sudo apt-get upgrade -y
ubuntu@duo2fa-test-free:~ curl -s https://duo.com/■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■/Ubuntu trusty main' | sudo tee /etc/apt/sources.list.d/duosecurity.list
ubuntu@duo2fa-test-free:~ sudo apt-get update && sudo apt-get install duo-unix
ubuntu@duo2fa-test-free:~$ cat <<EOF | sudo tee /etc/duo/duo_login.conf
ikey =
skey =
host =
groups = users,!root
failmode = safe
pushinfo = yes
http_proxy = http://cloud-proxy:3128/
autopush = yes
motd = yes
prompts = 1
accept_env_factor = no
fallback_local_ip = no
https_timeout = 0
EOF
I have tried this on multiple fresh ubuntu 14.04 vms on digitalocean and on my local laptop with the same result. I have also built from source and again i get permission denied without any form of prompt for an authenticator.
Is there a way to enforce 2fa for non-root users without locally installing login_duo?
01-30-2017 12:57 PM
Are you trying to install PAM Duo or Login Duo? You linked to the PAM doc but then mention duo_login.conf (so, Login Duo).
In the enabling section of Logon Duo’s instruction we do warn you that ForceCommand does run login_duo using the user’s shell.
To deploy Duo Unix to everyone, we recommend following the PAM Duo instructions. Have you tried following that process yet?
