DUO with Atlassian Crowd
popo1
DuoKristina
No, duo_universal_atlassian is just for on-premises Confluence and Jira deployments.
Does Crowd support use of an external SAML or OIDC identity provider? If so then you might be able to have it use Duo SSO for authentication.
If you migrate from on-prem to cloud solutions, we do have a named SSO integration for Atlassian Cloud apps.
Duo, not DUO.
popo1
Thanks for the answer. So it’s complicated. In Crowd we do have users from MS AD and also internal crowd users. So maybe the best way is to move identity provider service from crowd to DUO.
