05-30-2023 06:58 AM
Is it possible to protect Atlassian Crowd?
I have protected jira with GitHub - duosecurity/duo_universal_atlassian: Duo two-factor authentication plugin for Jira or Confluence with the Duo Universal Prompt.
but can I use it also for Crowd?
06-09-2023 10:39 AM
No, duo_universal_atlassian is just for on-premises Confluence and Jira deployments.
Does Crowd support use of an external SAML or OIDC identity provider? If so then you might be able to have it use Duo SSO for authentication.
If you migrate from on-prem to cloud solutions, we do have a named SSO integration for Atlassian Cloud apps.
06-09-2023 11:37 AM
Thanks for the answer. So it’s complicated. In Crowd we do have users from MS AD and also internal crowd users. So maybe the best way is to move identity provider service from crowd to DUO.
