How to force new authentication in web application
Olof_Olsson
Before implementing DUO as IDP for Microsoft Azure AD, we could use Microsoft identity platform to force new authentication with user name and password + optional MFA, setting prompt to login:
https://learn.microsoft.com/en-us/azure/active-directory/develop/msal-js-prompt-behavior
Can you recommend an alternative using DUO to force new authentication in web application?
New authentication is used as digital signature.
DuoPablo
Hi @Olof_Olsson ,
Duo authentication is invoked only when the protected application enters a primary authn workflow, meaning that Duo cannot override the application once a user has been logged in. The application must perform a session timeout/expiry/logout in order to allow Duo to prompt for 2FA (again, only after primary authn succeeds). If using Azure, AD you might look into the use of Refresh Tokens or similar: Refresh tokens in the Microsoft identity platform - Microsoft Entra | Microsoft Learn
Thanks!
