LDAPS not sending push
EvolutionXtinct
Hello, we have LDAPS working in our environment using our Duo Proxy Server, I see the information in the debug log, but the duo push isn’t happening. we have multiple applications using LDAP and they all work, this allows me to login but does not send the push even when the config is set to PUSH required.
Currently utilizing 3.1 Authentication Proxy
Amy2
Level 5
Level 5
Hi @EvolutionXtinct
Please contact the Duo Support team for assistance with your issue. Be sure to reference your community thread when you do so. You will find more information about how to contact support in our community guide.
