NameID issue + DUO + Azure SSO integration
sww1
Hi! I’m trying to enable DUO Sign Sign On for our own product. Azure AD is configured as authentication source. But when I test Single Sign On on login page I see such error: Error: Cannot create Name ID. Source attribute 'Email' does not exist. Error Trace ID: 9 0 e 6 b f 7 e 9 a 0 7 5 b 9 3 1 c e90493,I don't know which step went wrong. I would appreciate everyone who can help solve this issue. Thanks!
raulgc
Hello sww1.
I do believe your problem comes from this parameter:
I say this because I had your exact same situation not long ago, trying to configure it. The parameter that should go there is the way you named the addicional claim with the value user.userprincipalname on your Azure application:
Try this and tell me if it worked!
Thank you for your help! My problem has been resolved.
No problem! Please mark the answer to let other people with the same issue find the answer fast. Goodbye!
