Problem install in WordPress
mierlp
After installing the plugin in WordPress i don’t get to possibility to activate the plugin
instead when is go to a other menu opties the site is try to close and show the login screen.
This fails and i get something like this (sorry it’s dutch, but it says ‘Page can’t be reached’)
When i try to login again i got the same screen. Now i have to go with a ftp to the plugin directory and remove the complete plugin directory [duo-wordpress]. After that i can login
Kan deze pagina niet bereiken
Probeer dit
* Zorg dat u het juiste webadres hebt: https://f6omiz6ium45ou1svclvuxeteurl5welmxtsi4nu
* Zoek naar "https://f6omiz6ium45ou1svclvuxeteurl5welmxtsi4nu" op Bing
* Vernieuw de pagina
Catchlight
I had this same issue. I suspect it was another security plugin conflicting???
Do you have any security plugins running?
Amy2
Level 5
Level 5
Adding to what @Catchlight said, some WordPress plugins cause authentication issues when used together with Duo for WordPress. We recommend disabling any other plugins that appear to be causing problems.
Not sure that’s what is happening here, but it is worth a try! Check out our FAQ on Duo for WordPress for more.
