Setting hardware tokens as primary authentication method
glark
I’m trying to find out if there is a way to configure a hardware token as the primary authentication method for someone’s account (if you have other things set up like a phone on that account). In the duo self service portal, it does not show the hardware token as an option in the default device drop-down, and I don’t see any settings in the admin panel to make it so. If anybody knows if / how this can be done that would be awesome.
As a side note, this would primarily be while using Duo with office 365 (through conditional access), though it doesn’t seem to work other places we have it implemented either.
glark
Actually, never mind – I didn’t realize you could just select enter passcode and have that work with the hardware token instead / as well as the phone’s soft token.
RTStabler
Is there a way to do this? I have a subset of users who work in an environment where they cannot have their cell phones. I recognize they can push cancel and then enter the passcode, but if I can reduce a step for them that will make this user a base a bit happier.
