UAC Not Prompting
Jbrown06
I have a new install Windows 11 Machine. I installed 'Duo-Win-Login-4.3.1' and only require a prompt for UAC elevations only. This was working, but has suddenly stopped.
I have checked the reg keys which look correct. What else can i do to troubleshoot? Ive attached the 2 logs
DuoKristina
These are credentialed UAC requests (where you have to enter username and password)? Duo won't fire off for non-credentialed elevation.
Have you tried uninstalling and reinstalling?
You can also enable debug logging and take a look to see if it has more actionable info.
Please don't post your debug log here. If you want actual support you can open a case with Duo Support https://duo.com/support and send your debug log to a support engineer.
Duo, not DUO.
